Network monitor problems
  • Aspar
    • Dec 2005
    Hi all,
    I'm testing beta 7 but I've problems with network monitor.
    my /tmp/zabbix_agent.tmp is:
    netloadout1[lo] 90.666667
    netloadout5[lo] 83.306667
    netloadout15[lo] 99.173333
    netloadin1[lo] 90.666667
    netloadin5[lo] 83.306667
    netloadin15[lo] 99.173333
    netloadout1[eth0] 1834.666667
    netloadout5[eth0] 1960.106667
    netloadout15[eth0] 9122.986667
    netloadin1[eth0] 3238.400000
    netloadin5[eth0] 2690.986667
    netloadin15[eth0] 11958.186667
    disk_read_ops1[sda] 0.000000
    disk_read_ops5[sda] 0.013333
    disk_read_ops15[sda] 0.007778
    disk_read_blks1[sda] 0.000000
    disk_read_blks5[sda] 0.106667
    disk_read_blks15[sda] 0.062222
    disk_write_ops1[sda] 5.066667
    disk_write_ops5[sda] 5.573333
    disk_write_ops15[sda] 8.326667
    disk_write_blks1[sda] 155.733333
    disk_write_blks5[sda] 155.946667
    disk_write_blks15[sda] 261.475556
    cpu[idle1] 98.351648
    cpu[idle5] 97.699890
    cpu[idle15] 95.960338
    cpu[user1] 1.339286
    cpu[user5] 1.680586
    cpu[user15] 3.127295
    cpu[nice1] 0.025755
    cpu[nice5] 0.049630
    cpu[nice15] 0.041889
    cpu[system1] 0.480769
    cpu[system5] 0.592141
    cpu[system15] 0.852116
    but in the /tmp/zabbix_server
    001916:20060314:100031 Parameter [netloadout15[eth0]] is not supported by agent on host [mx1.test.com] Old status [0]
    001916:20060314:100032 Parameter [netloadin15[eth0]] is not supported by agent on host [mx1.test.com] Old status [0]
    001916:20060314:100034 Parameter [proc_cnt[mysqld]] is not supported by agent on host [mx1.test.com] Old status [0]
    001916:20060314:100035 Parameter [disk_write_ops1[hdb]] is not supported by agent on host [mx1.test.com] Old status [0]
    001916:20060314:100036 Parameter [netloadout1[lo]] is not supported by agent on host [mx1.test.com] Old status [0]
    001916:20060314:100037 Parameter [disk_read_ops15[hda]] is not supported by agent on host [mx1.test.com] Old status [0]
    001916:20060314:100037 Parameter [netloadin1[lo]] is not supported by agent on host [mx1.test.com] Old status [0]
    001916:20060314:100037 Parameter [vfs.file.cksum[/vmlinuz]] is not supported by agent on host [mx1.test.com] Old status [0]
    001916:20060314:100039 Parameter [sensor[temp1]] is not supported by agent on host [mx1.test.com] Old status [0]
    001916:20060314:100040 Parameter [net[listen_80]] is not supported by agent on host [mx1.test.com] Old status [0]
    So I can't monitor network bandwidth... The agent is the same version of the server (builded with the configure options in the 1.1 version manual)
    P.S. The linux distribution is a scientificlinux 3.05 (kernel 2.4)
    Alfonso
  • Aspar
    • Dec 2005
    Hi, i've executed the command: zabbix_agentd -p
    and I can't see any metrics on netloadin / out.
    That metrics are present into the beta2 agent client...
    Any one can help me?
    • SAT QPass
      • Oct 2005
      • 61
      zabbix-1.1beta5+? has some aggressive changes in the item names and the old names have been DEPRICATED. It caught me off guard when I upgraded.
      You would do well to examine this link zabbix supported items. Most everything you have above has been replaced with a more canonical name. The documentation is a bit behind, but not drastically.
      Hope this helps.
      • Aspar
        • Dec 2005
        Yes, I've readed that page but the netloadin1,5 and 15 are the averagare input traffic into a network card instead the net.if.in in the total traffic from the start of the times... How can I obtain a bps stats?
        • mdasilva
          • Feb 2006
          im with you
          can someone pls provide a full list of supported keys in 1.1beta7? i know its beta. i know there are some bugs. but some docs would be more useful instead of a forum saturated with the same problems. im sure updating a list of new keys for each beta release wouldnt be too painful.
          • elkor
            • Jul 2005
            • 299
            http://www.zabbix.com/doku/doku.php?...upported_items
