no hyperlinks on maps in screens?
  • elkor
    • Jul 2005
    • 299
    Is it just me or are network maps that are embedded in a screen no longer clickable? they seem to work fine when accessed as a map, but when you go to a screen that contains a map it just seems to be a graphic with no links.
    I've been doing modifications to 1.1beta7 for my installation here and I noticed this problem. While I had edited screens.php, I checked it with the version from the distribution and got the same result.
    does anybody else see this on 1.1beta7? it could be the result of one of my other modifications I guess, but it doesn't look like it at the moment.
