Win32 Agent under XP, W2k & 2003
  • kriebgui
    • Mar 2006
    The Win32 Agent send only information about System-State and Apache-State to Zabbix Server. Linux-Agent send more information.
    What functions are supported by Zabbix on the Windows Machines (XP,W2k,2003,NT).
    The Featurepage from Zabbix say: it support Windows Clients, but i have found on the Forums that only 2003 Support by Zabbix?!
    Please help me.
  • Piltrafa
    • Mar 2006
    I have a working Win2000 Server client, actualy is the one i use for test zabbix.
    To see de items and parameters for Win32 Hosts you need to look a the manual:
    http://www.zabbix.com/manual/v1.1/config_items.php
    And read the de ReadMe.txt File you found in:
    zabbix/src/zabbix_agent_win32/doc/
    • mbrijun
      • Mar 2006
      • 63
      having the same problems as Kriebgui. After installing the agent (that came with the 1.1beta7) most of the items on the server appear as "not supported". I am able to define my own items following the link by Piltrafa. However, it is not clear why simple operations like checking CPU load would require extra configuration.
      • bbrendon
        • Sep 2005
        • 873
        i added this to the faq. seems everyone that is new to zabbix asks this.
        Unofficial Zabbix Expert
        Blog, Corporate Site
