disksize > 2TB on NetApp (OS: ONTAP)
  • christoph.naef
    • Mar 2011
    Hoi,
    I'm having troubles to find a solution with the problem of monitoring disks with more than 2TB size. I'm using zabbix 1.8.8 server, target is NetApp with ONTAP. My setting looks like this (attachment). The result of that is shown as "16EB". I've tried different values in the "key" field with no success. Also the search in the archive of this forum gave some hints, but I wasn't able to match them with my setting/problem.
    Someone got any idea what to try?
    Thanks,
    Chris
  • christoph.naef
    • Mar 2011
    using df64UsedKBytes ( .1.3.6.1.4.1.789.1.5.4.1.29 ) with v2 solved the problem.
    Thx,
    Chris
