DM Child Node Not Sending Events
  • kollymars
    • Nov 2011
    I have a three node setup.
    Both children are set up to send event and history to the master, and I can see in the logs where they are sending. I can also see on the master where the data is being received in the zabbix_server.log file.
    I can see history on the web gui and events for node 3, but not for node 2. The problem with this is that the master is not sending alerts for triggers on node 2.
    Of course I can set up alerts on the node server itself, but I would rather have it work like node 3 does.
    Any help is appreciated.
  • mattsmith
    • Aug 2010
    • 33
    Hi kollymars
    Did you ever solve this? i'm having the same issue.
    Matt
    • harmonica
      • Jan 2009
      • 251
      Will not long ago I had problems with synchronization of events, but in my case it was related to the problem described here:
      • kollymars
        • Nov 2011
        Problem Fixed
        Thank you all so much. My problem is fixed using https://support.zabbix.com/browse/ZBX-3996
