psql issue in the installation
  • cipher
    • Nov 2011
    Hi there,
    I just wanted to install Zabbix and found a HowTo for debian based systems, as we're running only debian systems.
    However in the HowTo it is said that I should logon to PostgreSQL and create Zabbix DB to populate it. The it says that I should go into psql which I did and then when I run the mentioned command:
    create user zabbix createdb password 'whatever'
    I get the error the there is no role zabbix
    If I try to say: CREATE ROLE zabbix
    and retry the mentioned command I still get the same error. As I am not quite familiar with PostgreSQL and its commands I hope one of you might be able to tell me what I am doing wrong.
    I have debian wheezy (32-Bit) installed in a VBox environment.
    If you need any further informations I'll provide them asap.
    Here is the Link to the HowTo I used: http://www.zabbix.com/wiki/howto/ins...8_on_debian_50
    Thanks in advance for helping
    Cipher
  • Colttt
    • Mar 2009
    • 878
    try this:
    Debian-User
    Sorry for my bad english
