Windows Host not receiving active checks SOLVED!
  • vanbarel
    • Oct 2011
    I have Zabbix Server and windows Agent v 1.8.3
    I have created an Active Check for a Windows Server:
    host configured in Zabbix Server: server487
    All passive check are functioning
    config file:
    Server=xxxxxxxx.245
    ServerPort=10051
    Hostname=[B]SERVER[/B]487
    ListenPort=10055
    StartAgents=5
    DebugLevel=3
    LogFile= C:\Program Files\Zabbix\node\zabbix_agentd.log
    Timeout=5
    EnableRemoteCommands=0
    In the log file in debug mode I read:
    5496:20111129:140356.391 Sending [{
    	"request":"active checks",
    	"host":"[B]SERVER[/B]487"}]
      5496:20111129:140356.391 Before read
      5496:20111129:140356.485 Got [{
    	"response":"success",
    	"data":[]}]
    As you can see, the host is saved lowercase in zabbix server but uppercase in Zabbix conf file.
    The result is that I get no error "Can't find hostname" but still I get no info on the problem.
    It would be nice if this uppercase/lowercase error gets a warning in the log (ie: the agent doesn't find the hostname because of different case, but still doesn't warn)
