SNMP Traps only work locally
  • daniel.satta
    • Dec 2011
    Hi Forum,
    I usually do not try to ask in forums, since most of the time the answers here are very clear and help getting along with the configuration. I also bought the Zabbix book which turned out to be really helpful. But now I got stuck with this SNMP trapper thing. Maybe somebody can advise ?
    I followed the instructions in the Manual (also in the book) to configure a simple SNMP trap.
    My Configuration:
    Zabbix Server 1.8.8 on Debian 6.0.3 - Squeeze
    NET-SNMP Package v5.4.3
    /etc/snmp/snmptrapd.conf:
    authCommunity execute public
    authCommunity execute PUBLIC
    traphandle default /bin/bash /etc/zabbix/scripts/snmptrap.sh
    disableAuthorization yes
    /etc/zabbix/scripts/snmptrap.sh:
    ZABBIX_SERVER="fqdn_of_zabbix_server";
    ZABBIX_PORT="10051";
    ZABBIX_SENDER="/opt/zabbix/bin/zabbix_sender";
    KEY="snmptraps";
    HOST="fqdn_of_host_to_be_monitored";
    # END OF CONFIGURATION
    read hostname
    read ip
    read uptime
    read oid
    read address
    read community
    read enterprise
    oid=`echo $oid|cut -f2 -d' '`
    address=`echo $address|cut -f2 -d' '`
    community=`echo $community|cut -f2 -d' '`
    enterprise=`echo $enterprise|cut -f2 -d' '`
    oid=`echo $oid|cut -f11 -d'.'`
    community=`echo $community|cut -f2 -d'"'`
    str="$hostname $address $community $enterprise $oid"
    $ZABBIX_SENDER -z $ZABBIX_SERVER -p $ZABBIX_PORT -s "$HOST" -k "$KEY" -o "$str"
    In Zabbix I configured an item for the host to be monitored with type 'zabbix trapper', key 'snmptraps' and type of information 'character'. Now, when I configure the Zabbix Server itself as the host to be monitored, configure the 'snmptraps' item for the zabbix server and drop the recommended test command on the shell, everything works fine. Still, this is just local traffic.
    Example:
    root@zabbix:/etc/zabbix/scripts# zabbix_sender -z zabbix -p 10051 -s zabbix -k snmptraps -o "blah blah blah"
    This command gives me the desired output in the Zabbix Web Frontend. So far, so good.
    However, if I configure another host across the network to send snmp traps to the zabbix server, respectively to the snmptrapd listening on the Zabbix server on Port 162, nothing happens. I already opened our firewall for UDP port 162, since I noticed that those packets were blocked before. What happens now is, that the SNMP packets arrive at the zabbix host and even at the zabbix server, but they won't be displayed in the web frontend.
    The output of tcpdump while sending the trap from another host looks like this:
    root@zabbix:/etc/zabbix/scripts# tcpdump -i eth0 port 162
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
    13:24:02.637632 IP HOST_WHO_SENDS_THE_TRAP.snmp > zabbix.snmp-trap: Trap(181) E:18928.1.1 192.168.0.XXX enterpriseSpecific s=679 1731451940 system.sysDescr.0="2025-8-14 14:22:32 : H/W Monitor : Test Event" system.sysContact.0="[email protected]" system.sysName.0="HOST_WHO_SENDS_THE_TRAP" system.sysLocation.0="S01"
    This means, the packet actually arrives at the Zabbix Host, but then disappears in Nirvana. I switched the Zabbix Server log to Debug mode to see if I can actually see if the server ever received this trap, but I can't confirm if it really does. Here's the output of the log file when I send a test event from the host to be monitored. Looks like there's some query sent to the database, but I can't really figure out why the desired text doesn't show up in the Zabbix frontend.
    24018:20111209:132741.526 query [txnlev:0] [select i.itemid,i.hostid,h.proxy_hostid,i.type,i.data_typ e,i.value_type,i.key_,i.snmp_community,i.snmp_oid, i.snmp_port,i.snmpv3_securityname,i.snmpv3_securit ylevel,i.snmpv3_authpassphrase,i.snmpv3_privpassph rase,i.ipmi_sensor,i.delay,i.delay_flex,i.trapper_ hosts,i.logtimefmt,i.params,i.status,i.authtype,i. username,i.password,i.publickey,i.privatekey from items i,hosts h where i.hostid=h.hostid and h.status in (0) and i.status in (0,3) and i.itemid between 000000000000000 and 099999999999999]
    24018:20111209:132741.578 query [txnlev:0] [select hostid,proxy_hostid,host,useip,ip,dns,port,useipmi ,ipmi_ip,ipmi_port,ipmi_authtype,ipmi_privilege,ip mi_username,ipmi_password,maintenance_status,maint enance_type,maintenance_from,errors_from,available ,disable_until,snmp_errors_from,snmp_available,snm p_disable_until,ipmi_errors_from,ipmi_available,ip mi_disable_until,status from hosts where status in (0,5,6) and hostid between 000000000000000 and 099999999999999]
    Is there anything I'm missing ?? Any help would be greatly appreciated.
    Best regards,
    Daniel
  • daniel.satta
    • Dec 2011
    Correction:
    To test the snmp trap from the shell, I don't use the zabbix_sender command as described before, but I'm of course using the snmptrap command, as described in the book. So
    should actually be
    root@zabbix:/etc/zabbix/scripts# snmptrap -Ci -v 2c -c public localhost "" "NET-SNMP-MIB::netSnmpExperimental" NET-SNMP-MIB:netSnmpExperimental s "blah blah blah"
    The zabbix_sender command ALSO gives me an error:
    Info from server: "Processed 0 Failed 1 Total 1 Seconds spent 0.000094"
    sent: 1; skipped: 0; total: 1
    I would be super glad if somebody can advise here.
    Thanks a lot in advance. Daniel
    • ncurry
      • Oct 2011
      Having the same problem
      I did exactly as you had and I am having the same exact problem. Have you been able to correct this?
      • richlv
        • Oct 2005
        • 3112
        that must be host _name_ - whatever is in the first field in host properties. is it so in your case ?
