hi,
I wonder if anyone has any solution to this issue - or insight into what might be causing it:
I have built the 1.8.9 version as a 32-bit (i686) zabbix agent on an ubuntu x86 system, and an x86_64 agent & server on an ubuntu x86_64 system.
The agent configurations are identical:
./configure \
--enable-agent \
--with-ldap \
--prefix=/usr/local/targetroot/zabbix-agent-32/usr
[i am then doing a debian package install from there.]
the x86_64 version (agent and server) work quite happily.
the x86 agent fails to pull anything useful (okay, so i get file checksums) from the Template_Linux template (I have removed some checks I don't need, but that's also true for the x86_64 versions. I simply get 'not supported' in the detailed items view of host configuration.
locally, running a "zabbix_get -s localhost -k system.cpu.util[,nice,avg1]" - for example (on the x86 box) I get no result (or any other message) - on the x86_64, I get the expected result.
does anyone have any idea what might be causing this... and what I can change to fix it?
thanks in advance,
Nick
./configure \
--enable-agent \
--with-ldap \
thanks in advance,
Nick
