zabbix_server does not do anything
  • arahman
    • Mar 2006
    When I try to run the zabbix_server process from bin directory at the end it does not do anything.
    When I try to rerun it , it says it already exists.
    please help
    thanks
  • arahman
    • Mar 2006
    unable to find net-snmp-includes.sh
    Just to let you know regarding my previos problem starting zabbix_server file from bin.
    When I compiled using ./configure --with-mysql --with-net-snmp --enable-server then everything went on well but I got an error at the end like this
    unable to find net-snmp-includes.sh.
    Does this help?
    • cameronsto
      • Oct 2005
      • 148
      This is because you don't have the net-snmp dev libraries installed.
      -cameron
      • shalako
        • Apr 2006
        • 30
        net-snmp dev libs
        what are the the net-snmp dev libs? i have the following installed in /usr/local/lib/
        libnetsnmp.a
        libnetsnmp.la
        libnetsnmp.so
        libnetsnmp.so.8
        libnetsnmp.so.8.0.0
        I have these installed and I get the following error when starting [/usr/local/bin] ./zabbix_suckerd
        ./zabbix_suckerd: error while loading shared libraries: libnetsnmp.so.8: cannot open shared object file: No such file or directory
        thank you
        • krusty
          • Oct 2005
          • 222
          You have to install snmp-devel paket. Then the error goes away.
          • shalako
            • Apr 2006
            • 30
            thanks
            i got the snmp-devel package installed. not available as source so i had to uninstall net-snmp, reinstall from rpm, then install net-snmp-devel from rpm.
            but after rebuilding zabbix, i was able to start zabbix_server. and I think the "Warning: bad syntax, perhaps a bogus '-'?" apache error from report1.php seems to have gone away, too.
            finally, i still can't login to the web interface. I've tried php4 and 5, as cgi and as module. i've tried mysql3 and 5. i confirmed mysql can connect to the db as user zabbix and that there is no password for alias Admin. help?
            • elkor
              • Jul 2005
              • 299
              does the zabbix database user have the correct permissions for the zabbix database? (aside from being able to login to mysql that is)
              • shalako
                • Apr 2006
                • 30
                I granted all privileges to user zabbix on db zabbix.
                Just confirmed Cookies are enabled in my browser, as others have suggested. They are. I deleted the cookies. Tried logging in again. Still no luck. No error message, just the login/index page refreshed.
