I'm using the Zabbix-API to get the active triggers and show them on another website.
I've managed to make a json-query like this:
And it gives me the results I want:
As you can see we use macro's in the trigger description.
In this case only {HOSTNAME} but we've got many triggers with even more macros.
Is it possible to convert the Macro to the actual value?
In the API-Docs I found that there is a property called "expandDescription string Expands trigger description Expands macros" and it accepts a string.
But I haven't found out what kind of stringvalue to use! The documentation isn't very clear on many of these properties unfortunaly.
Is it even possible to "expand" theses macros to their actual value?
Many thanks in advance!
"jsonrpc":"2.0",
"id":17,
"auth":"8a9bbe31b0c4b9a7680967e975a558e3",
"method":"trigger.get",
"params":{
"extendoutput":true,
"limit":1000,
"monitored":"1",
"active":"1",
"only_true":"1",
"min_severity":"3",
"sortfield":"lastchange",
"sortorder":"ASC",
"user":"apiuser",
"password":"********"
"jsonrpc":"2.0",
"result":[{
"triggerid":"24754",
"expression":"{81697}",
"description":"3001 No SNMP data {HOSTNAME}",
"url":"",
"status":"0",
"value":"1",
"priority":"3",
"lastchange":"1325027672",
"dep_level":"0",
"comments":"",
"error":"",
"templateid":"30581","type":"0"
"triggerid":"51135",
"expression":"{120611}<1",
"description":"5201 Process LDAP not running {HOSTNAME}",
"url":"",
"status":"0",
"value":"1",
"priority":"4",
"lastchange":"1325059579",
"dep_level":"0",
"comments":"",
"error":"",
"templateid":"47017",
"type":"0"
"id":17
