"Host x unreachable" - from one day of another... 4 vServers
  • lippoliv
    • Oct 2011
    • 15
    Hey there,
    I have 5 vServers, one just for monitoring the other 4, 3 of them WebServers and one is an GameServer.
    Since yesterday I got one unknonown status for each vServer...
    Yesterday I switched over to use Template_Linux for all of the vServers so I can manage Graphs, etc. from just one point.
    Now Server-Log says:
     17393:20111229:093748.494 Sending list of active checks to [x] failed: host [x] not found
     17393:20111229:093803.809 Sending list of active checks to [y] failed: host [y] not found
     17389:20111229:093814.063 Sending list of active checks to [127.0.0.1] failed: host [localhost] not found
     17391:20111229:093814.588 Sending list of active checks to [z] failed: host [z] not found
    Has someone an Idea what I can do?
  • adriano
    • Jan 2011
    • 26
    are you using active checks?
    maybe the Host Name or Host DNS in the host configuration is not the same of the Hostname in the client zabbix_agentd.conf file..
    • lippoliv
      • Oct 2011
      • 15
      Hey there, thanks for writing
      In ZAbbix I named them like "WebServer 1" and "WebServer 2", the host dns and host IP is correct.
      Do you need more infos to help me?
      • adriano
        • Jan 2011
        • 26
        ok..
        Configurations from the servers in the frontend
        Host Name:
        Host DNS:
        and the configuration on the agent:
        Hostname=
        the thing is: the host name in the FRONTEND need to be the same in the zabbix_agentd.conf..
        are you monitoring then using DNS name or IP address?
        kind regards,
