Hello all,
The zabbix server is crashing on startup.
What can we do about it? Is that a bug?
The server has version 1.8.7 and was running for months until now.
The filesystem goes to empty and the service down. After this it doesn't start anymore.
Any help or comment will be appreciated.
Following the zabbix-server.log:
27599:20111229:172936.075 Starting Zabbix Server. Zabbix 1.8.7 (revision 21394).
27599:20111229:172936.076 ****** Enabled features ******
27599:20111229:172936.076 SNMP monitoring: YES
27599:20111229:172936.076 IPMI monitoring: YES
27599:20111229:172936.076 WEB monitoring: YES
27599:20111229:172936.076 Jabber notifications: YES
27599:20111229:172936.076 Ez Texting notifications: YES
27599:20111229:172936.076 ODBC: NO
27599:20111229:172936.076 SSH2 support: YES
27599:20111229:172936.076 IPv6 support: NO
27599:20111229:172936.076 ******************************
27601:20111229:172936.102 server #1 started [configuration syncer #1]
27602:20111229:172936.103 server #2 started [db watchdog #1]
27611:20111229:172936.108 server #9 started [trapper #1]
27612:20111229:172936.109 server #10 started [trapper #2]
27614:20111229:172936.109 server #11 started [trapper #3]
27615:20111229:172936.110 server #12 started [trapper #4]
27617:20111229:172936.110 server #13 started [trapper #5]
27620:20111229:172936.111 server #14 started [icmp pinger #1]
27623:20111229:172936.112 server #15 started [alerter #1]
27624:20111229:172936.113 server #16 started [housekeeper #1]
27624:20111229:172936.113 Executing housekeeper
27626:20111229:172936.113 server #17 started [timer #1]
27628:20111229:172936.114 server #18 started [http poller #1]
27632:20111229:172936.116 server #20 started [history syncer #1]
27633:20111229:172936.116 server #21 started [history syncer #2]
27635:20111229:172936.117 server #22 started [history syncer #3]
27639:20111229:172936.118 server #24 started [escalator #1]
27640:20111229:172936.118 server #25 started [proxy poller #1]
27642:20111229:172936.119 server #26 started [self-monitoring #1]
27599:20111229:172936.119 server #0 started [main process]
27637:20111229:172936.118 server #23 started [history syncer #4]
27626:20111229:172936.123 Got signal [signal:11(SIGSEGV),reason:1,refaddr
nil)]. Crashing ...
27626:20111229:172936.123 ====== Fatal information: ======
27626:20111229:172936.123 Program counter: 0x360c479b80
27626:20111229:172936.123 === Registers: ===
27626:20111229:172936.123 r8 = fefefefefefefeff = 18374403900871474943 = -72340172838076673
27626:20111229:172936.123 r9 = 0 = 0 = 0
27626:20111229:172936.123 r10 = 22000 = 139264 = 139264
27626:20111229:172936.123 r11 = 360c47aec6 = 232134258374 = 232134258374
27626:20111229:172936.123 r12 = 81f = 2079 = 2079
27626:20111229:172936.123 r13 = 479d3e = 4693310 = 4693310
27626:20111229:172936.123 r14 = 18dde410 = 417195024 = 417195024
27626:20111229:172936.123 r15 = 4efcbfa0 = 1325186976 = 1325186976
27626:20111229:172936.123 rdi = 0 = 0 = 0
27626:20111229:172936.123 rsi = 81f = 2079 = 2079
27626:20111229:172936.123 rbp = 0 = 0 = 0
27626:20111229:172936.123 rbx = 9 = 9 = 9
27626:20111229:172936.123 rdx = 0 = 0 = 0
27626:20111229:172936.123 rax = 0 = 0 = 0
27626:20111229:172936.123 rcx = 0 = 0 = 0
27626:20111229:172936.123 rsp = 7fff4139cb08 = 140734287694600 = 140734287694600
27626:20111229:172936.123 rip = 360c479b80 = 232134253440 = 232134253440
27626:20111229:172936.124 efl = 10246 = 66118 = 66118
27626:20111229:172936.124 csgsfs = 33 = 51 = 51
27626:20111229:172936.124 err = 4 = 4 = 4
27626:20111229:172936.124 trapno = e = 14 = 14
27626:20111229:172936.124 oldmask = 0 = 0 = 0
27626:20111229:172936.124 cr2 = 0 = 0 = 0
27626:20111229:172936.124 === Backtrace: ===
27626:20111229:172936.124 14: /usr/local/sbin/zabbix_server(print_fatal_info+0xdb) [0x43e20b]
27626:20111229:172936.124 13: /usr/local/sbin/zabbix_server [0x43da38]
27626:20111229:172936.124 12: /lib64/libc.so.6 [0x360c4302d0]
27626:20111229:172936.124 11: /lib64/libc.so.6(strlen+0x30) [0x360c479b80]
27626:20111229:172936.124 10: /lib64/libc.so.6(__strdup+0x16) [0x360c4798b6]
27626:20111229:172936.124 9: /usr/local/sbin/zabbix_server(zbx_strdup2+0x3e) [0x4432ae]
27626:20111229:172936.124 8: /usr/local/sbin/zabbix_server(DBget_history+0x268) [0x45b6c8]
27626:20111229:172936.124 7: /usr/local/sbin/zabbix_server [0x44df1a]
27626:20111229:172936.124 6: /usr/local/sbin/zabbix_server(evaluate_function+0x2b8) [0x44f6c8]
27626:20111229:172936.124 5: /usr/local/sbin/zabbix_server(evaluate_expression+0x4cd) [0x45536d]
27626:20111229:172936.124 4: /usr/local/sbin/zabbix_server(main_timer_loop+0x1e6) [0x41e7d6]
27626:20111229:172936.124 3: /usr/local/sbin/zabbix_server(MAIN_ZABBIX_ENTRY+0x7fe) [0x41102e]
27626:20111229:172936.124 2: /usr/local/sbin/zabbix_server(daemon_start+0x245) [0x43d685]
27626:20111229:172936.124 1: /lib64/libc.so.6(__libc_start_main+0xf4) [0x360c41d994]
27626:20111229:172936.124 0: /usr/local/sbin/zabbix_server [0x40d369]
27626:20111229:172936.124 === Memory map: ===
27626:20111229:172936.124 00400000-00486000 r-xp 00000000 fd:04 394084 /usr/local/sbin/zabbix_server
27626:20111229:172936.124 00686000-006ab000 rw-p 00086000 fd:04 394084 /usr/local/sbin/zabbix_server
27626:20111229:172936.124 006ab000-006b1000 rw-p 006ab000 00:00 0
27626:20111229:172936.124 18da5000-18e09000 rw-p 18da5000 00:00 0 [heap]
27626:20111229:172936.124 30c8a00000-30c8a02000 r-xp 00000000 fd:00 655371 /lib64/libcom_err.so.2.1
27626:20111229:172936.124 30c8a02000-30c8c01000 ---p 00002000 fd:00 655371 /lib64/libcom_err.so.2.1
27626:20111229:172936.124 30c8c01000-30c8c02000 rw-p 00001000 fd:00 655371 /lib64/libcom_err.so.2.1
27626:20111229:172936.125 30c8e00000-30c8f2a000 r-xp 00000000 fd:04 688199 /usr/lib64/mysql/libmysqlclient.so.15.0.0
27626:20111229:172936.125 30c8f2a000-30c9129000 ---p 0012a000 fd:04 688199 /usr/lib64/mysql/libmysqlclient.so.15.0.0
27626:20111229:172936.125 30c9129000-30c9170000 rw-p 00129000 fd:04 688199 /usr/lib64/mysql/libmysqlclient.so.15.0.0
27626:20111229:172936.125 30c9170000-30c9171000 rw-p 30c9170000 00:00 0
27626:20111229:172936.125 30c9200000-30c9224000 r-xp 00000000 fd:04 625238 /usr/lib64/libk5crypto.so.3.1
27626:20111229:172936.125 30c9224000-30c9423000 ---p 00024000 fd:04 625238 /usr/lib64/libk5crypto.so.3.1
27626:20111229:172936.125 30c9423000-30c9425000 rw-p 00023000 fd:04 625238 /usr/lib64/libk5crypto.so.3.1
27626:20111229:172936.125 30c9600000-30c960c000 r-xp 00000000 fd:04 625244 /usr/lib64/libiksemel.so.3.1.1
27626:20111229:172936.125 30c960c000-30c980c000 ---p 0000c000 fd:04 625244 /usr/lib64/libiksemel.so.3.1.1
27626:20111229:172936.125 30c980c000-30c980d000 rw-p 0000c000 fd:04 625244 /usr/lib64/libiksemel.so.3.1.1
27626:20111229:172936.125 30c9a00000-30c9a91000 r-xp 00000000 fd:04 625239 /usr/lib64/libkrb5.so.3.3
27626:20111229:172936.125 30c9a91000-30c9c91000 ---p 00091000 fd:04 625239 /usr/lib64/libkrb5.so.3.3
27626:20111229:172936.125 30c9c91000-30c9c95000 rw-p 00091000 fd:04 625239 /usr/lib64/libkrb5.so.3.3
27626:20111229:172936.125 30c9e00000-30c9e46000 r-xp 00000000 fd:00 655375 /lib64/libssl.so.0.9.8e
27626:20111229:172936.125 30c9e46000-30ca046000 ---p 00046000 fd:00 655375 /lib64/libssl.so.0.9.8e
27626:20111229:172936.125 30ca046000-30ca04c000 rw-p 00046000 fd:00 655375 /lib64/libssl.so.0.9.8e
27626:20111229:172936.125 30ca600000-30ca631000 r-xp 00000000 fd:04 625249 /usr/lib64/libidn.so.11.5.19
27626:20111229:172936.125 30ca631000-30ca830000 ---p 00031000 fd:04 625249 /usr/lib64/libidn.so.11.5.19
27626:20111229:172936.125 30ca830000-30ca831000 rw-p 00030000 fd:04 625249 /usr/lib64/libidn.so.11.5.19
27626:20111229:172936.125 30cae00000-30cae3b000 r-xp 00000000 fd:04 625250 /usr/lib64/libcurl.so.3.0.0
27626:20111229:172936.125 30cae3b000-30cb03b000 ---p 0003b000 fd:04 625250 /usr/lib64/libcurl.so.3.0.0
27626:20111229:172936.125 30cb03b000-30cb03d000 rw-p 0003b000 fd:04 625250 /usr/lib64/libcurl.so.3.0.0
27626:20111229:172936.125 360c000000-360c01c000 r-xp 00000000 fd:00 655555 /lib64/ld-2.5.so
27626:20111229:172936.125 360c21b000-360c21c000 r--p 0001b000 fd:00 655555 /lib64/ld-2.5.so
27626:20111229:172936.125 360c21c000-360c21d000 rw-p 0001c000 fd:00 655555 /lib64/ld-2.5.so
27626:20111229:172936.125 360c400000-360c54e000 r-xp 00000000 fd:00 655556 /lib64/libc-2.5.so
27626:20111229:172936.125 360c54e000-360c74e000 ---p 0014e000 fd:00 655556 /lib64/libc-2.5.so
27626:20111229:172936.125 360c74e000-360c752000 r--p 0014e000 fd:00 655556 /lib64/libc-2.5.so
27626:20111229:172936.125 360c752000-360c753000 rw-p 00152000 fd:00 655556 /lib64/libc-2.5.so
27626:20111229:172936.125 360c753000-360c758000 rw-p 360c753000 00:00 0
27626:20111229:172936.125 360c800000-360c802000 r-xp 00000000 fd:00 655557 /lib64/libdl-2.5.so
27626:20111229:172936.125 360c802000-360ca02000 ---p 00002000 fd:00 655557 /lib64/libdl-2.5.so
27626:20111229:172936.125 360ca02000-360ca03000 r--p 00002000 fd:00 655557 /lib64/libdl-2.5.so
27626:20111229:172936.125 360ca03000-360ca04000 rw-p 00003000 fd:00 655557 /lib64/libdl-2.5.so
27626:20111229:172936.125 360cc00000-360cc90000 r-xp 00000000 fd:04 622859 /usr/lib64/libnetsnmp.so.10.0.3
27626:20111229:172936.125 360cc90000-360ce90000 ---p 00090000 fd:04 622859 /usr/lib64/libnetsnmp.so.10.0.3
27626:20111229:172936.125 360ce90000-360ce94000 rw-p 00090000 fd:04 622859 /usr/lib64/libnetsnmp.so.10.0.3
27626:20111229:172936.125 360ce94000-360cec8000 rw-p 360ce94000 00:00 0
27626:20111229:172936.125 360d000000-360d015000 r-xp 00000000 fd:00 655562 /lib64/libselinux.so.1
27626:20111229:172936.125 360d015000-360d215000 ---p 00015000 fd:00 655562 /lib64/libselinux.so.1
27626:20111229:172936.125 360d215000-360d217000 rw-p 00015000 fd:00 655562 /lib64/libselinux.so.1
27626:20111229:172936.125 360d217000-360d218000 rw-p 360d217000 00:00 0
27626:20111229:172936.125 360d400000-360d52d000 r-xp 00000000 fd:00 655569 /lib64/libcrypto.so.0.9.8e
27626:20111229:172936.125 360d52d000-360d72c000 ---p 0012d000 fd:00 655569 /lib64/libcrypto.so.0.9.8e
27626:20111229:172936.125 360d72c000-360d74d000 rw-p 0012c000 fd:00 655569 /lib64/libcrypto.so.0.9.8e
27626:20111229:172936.125 360d74d000-360d751000 rw-p 360d74d000 00:00 0
27626:20111229:172936.125 360d800000-360d882000 r-xp 00000000 fd:00 655570 /lib64/libm-2.5.so
27626:20111229:172936.125 360d882000-360da81000 ---p 00082000 fd:00 655570 /lib64/libm-2.5.so
27626:20111229:172936.125 360da81000-360da82000 r--p 00081000 fd:00 655570 /lib64/libm-2.5.so
27626:20111229:172936.125 360da82000-360da83000 rw-p 00082000 fd:00 655570 /lib64/libm-2.5.so
27626:20111229:172936.125 360dc00000-360dc11000 r-xp 00000000 fd:00 655578 /lib64/libresolv-2.5.so
27626:20111229:172936.125 360dc11000-360de11000 ---p 00011000 fd:00 655578 /lib64/libresolv-2.5.so
27626:20111229:172936.125 360de11000-360de12000 r--p 00011000 fd:00 655578 /lib64/libresolv-2.5.so
27626:20111229:172936.125 360de12000-360de13000 rw-p 00012000 fd:00 655578 /lib64/libresolv-2.5.so
27626:20111229:172936.125 360de13000-360de15000 rw-p 360de13000 00:00 0
27626:20111229:172936.125 360e000000-360e014000 r-xp 00000000 fd:04 624793 /usr/lib64/libz.so.1.2.3
27626:20111229:172936.125 360e014000-360e213000 ---p 00014000 fd:04 624793 /usr/lib64/libz.so.1.2.3
27626:20111229:172936.125 360e213000-360e214000 rw-p 00013000 fd:04 624793 /usr/lib64/libz.so.1.2.3
27626:20111229:172936.125 360e400000-360e415000 r-xp 00000000 fd:00 655483 /lib64/libnsl-2.5.so
27626:20111229:172936.125 360e415000-360e614000 ---p 00015000 fd:00 655483 /lib64/libnsl-2.5.so
27626:20111229:172936.125 360e614000-360e615000 r--p 00014000 fd:00 655483 /lib64/libnsl-2.5.so
27626:20111229:172936.125 360e615000-360e616000 rw-p 00015000 fd:00 655483 /lib64/libnsl-2.5.so
27626:20111229:172936.125 360e616000-360e618000 rw-p 360e616000 00:00 0
27626:20111229:172936.125 360e800000-360e809000 r-xp 00000000 fd:00 655567 /lib64/libcrypt-2.5.so
27626:20111229:172936.125 360e809000-360ea08000 ---p 00009000 fd:00 655567 /lib64/libcrypt-2.5.so
27626:20111229:172936.125 360ea08000-360ea09000 r--p 00008000 fd:00 655567 /lib64/libcrypt-2.5.so
27626:20111229:172936.125 360ea09000-360ea0a000 rw-p 00009000 fd:00 655567 /lib64/libcrypt-2.5.so
27626:20111229:172936.125 360ea0a000-360ea38000 rw-p 360ea0a000 00:00 0
27626:20111229:172936.125 360f400000-360f402000 r-xp 00000000 fd:00 655580 /lib64/libkeyutils-1.2.so
27626:20111229:172936.125 360f402000-360f601000 ---p 00002000 fd:00 655580 /lib64/libkeyutils-1.2.so
27626:20111229:172936.125 360f601000-360f602000 rw-p 00001000 fd:00 655580 /lib64/libkeyutils-1.2.so
27626:20111229:172936.125 360f800000-360f808000 r-xp 00000000 fd:04 622921 /usr/lib64/libkrb5support.so.0.1
27626:20111229:172936.126 360f808000-360fa07000 ---p 00008000 fd:04 622921 /usr/lib64/libkrb5support.so.0.1
27626:20111229:172936.126 360fa07000-360fa08000 rw-p 00007000 fd:04 622921 /usr/lib64/libkrb5support.so.0.1
27626:20111229:172936.126 3610800000-361080d000 r-xp 00000000 fd:00 655571 /lib64/libgcc_s-4.1.2-20080825.so.1
27626:20111229:172936.126 361080d000-3610a0d000 ---p 0000d000 fd:00 655571 /lib64/libgcc_s-4.1.2-20080825.so.1
27626:20111229:172936.126 3610a0d000-3610a0e000 rw-p 0000d000 fd:00 655571 /lib64/libgcc_s-4.1.2-20080825.so.1
27626:20111229:172936.126 2b45d94e7000-2b45d94ea000 rw-p 2b45d94e7000 00:00 0
27626:20111229:172936.126 2b45d94f2000-2b45d94f3000 rw-p 2b45d94f2000 00:00 0
27626:20111229:172936.126 2b45d94f3000-2b45d951f000 r-xp 00000000 fd:04 625240 /usr/lib64/libgssapi_krb5.so.2.2
27626:20111229:172936.126 2b45d951f000-2b45d971f000 ---p 0002c000 fd:04 625240 /usr/lib64/libgssapi_krb5.so.2.2
27626:20111229:172936.126 2b45d971f000-2b45d9721000 rw-p 0002c000 fd:04 625240 /usr/lib64/libgssapi_krb5.so.2.2
27626:20111229:172936.126 2b45d9721000-2b45d9724000 rw-p 2b45d9721000 00:00 0
27626:20111229:172936.126 2b45d9724000-2b45d972c000 r-xp 00000000 fd:00 655554 /lib64/libwrap.so.0.7.6
27626:20111229:172936.126 2b45d972c000-2b45d992b000 ---p 00008000 fd:00 655554 /lib64/libwrap.so.0.7.6
27626:20111229:172936.126 2b45d992b000-2b45d992d000 rw-p 00007000 fd:00 655554 /lib64/libwrap.so.0.7.6
27626:20111229:172936.126 2b45d992d000-2b45d994f000 r-xp 00000000 fd:04 625230 /usr/lib64/libssh2.so.1.0.1
27626:20111229:172936.126 2b45d994f000-2b45d9b4f000 ---p 00022000 fd:04 625230 /usr/lib64/libssh2.so.1.0.1
27626:20111229:172936.126 2b45d9b4f000-2b45d9b50000 rw-p 00022000 fd:04 625230 /usr/lib64/libssh2.so.1.0.1
27626:20111229:172936.126 2b45d9b50000-2b45d9b51000 rw-p 2b45d9b50000 00:00 0
27626:20111229:172936.126 2b45d9b51000-2b45d9c32000 r-xp 00000000 fd:04 625255 /usr/lib64/libOpenIPMI.so.0.0.5
27626:20111229:172936.126 2b45d9c32000-2b45d9e31000 ---p 000e1000 fd:04 625255 /usr/lib64/libOpenIPMI.so.0.0.5
27626:20111229:172936.126 2b45d9e31000-2b45d9e4d000 rw-p 000e0000 fd:04 625255 /usr/lib64/libOpenIPMI.so.0.0.5
27626:20111229:172936.126 2b45d9e4d000-2b45d9e51000 rw-p 2b45d9e4d000 00:00 0
27626:20111229:172936.126 2b45d9e51000-2b45d9e56000 r-xp 00000000 fd:04 625257 /usr/lib64/libOpenIPMIposix.so.0.0.1
27626:20111229:172936.126 2b45d9e56000-2b45da055000 ---p 00005000 fd:04 625257 /usr/lib64/libOpenIPMIposix.so.0.0.1
27626:20111229:172936.126 2b45da055000-2b45da056000 rw-p 00004000 fd:04 625257 /usr/lib64/libOpenIPMIposix.so.0.0.1
27626:20111229:172936.126 2b45da056000-2b45da057000 rw-p 2b45da056000 00:00 0
27626:20111229:172936.126 2b45da057000-2b45da0d1000 r-xp 00000000 fd:04 625243 /usr/lib64/libgnutls.so.13.0.6
27626:20111229:172936.126 2b45da0d1000-2b45da2d0000 ---p 0007a000 fd:04 625243 /usr/lib64/libgnutls.so.13.0.6
27626:20111229:172936.126 2b45da2d0000-2b45da2db000 rw-p 00079000 fd:04 625243 /usr/lib64/libgnutls.so.13.0.6
27626:20111229:172936.126 2b45da2db000-2b45da2dd000 rw-p 2b45da2db000 00:00 0
27626:20111229:172936.126 2b45da2dd000-2b45da2e4000 r-xp 00000000 fd:04 625226 /usr/lib64/libOpenIPMIutils.so.0.0.1
27626:20111229:172936.126 2b45da2e4000-2b45da4e3000 ---p 00007000 fd:04 625226 /usr/lib64/libOpenIPMIutils.so.0.0.1
27626:20111229:172936.126 2b45da4e3000-2b45da4e4000 rw-p 00006000 fd:04 625226 /usr/lib64/libOpenIPMIutils.so.0.0.1
27626:20111229:172936.126 2b45da4e4000-2b45da533000 r-xp 00000000 fd:04 625252 /usr/lib64/libncurses.so.5.5
27626:20111229:172936.126 2b45da533000-2b45da732000 ---p 0004f000 fd:04 625252 /usr/lib64/libncurses.so.5.5
27626:20111229:172936.126 2b45da732000-2b45da740000 rw-p 0004e000 fd:04 625252 /usr/lib64/libncurses.so.5.5
27626:20111229:172936.126 2b45da740000-2b45da742000 rw-p 2b45da740000 00:00 0
27626:20111229:172936.126 2b45da742000-2b45da748000 r-xp 00000000 fd:04 625256 /usr/lib64/libgdbm.so.2.0.0
27626:20111229:172936.126 2b45da748000-2b45da947000 ---p 00006000 fd:04 625256 /usr/lib64/libgdbm.so.2.0.0
27626:20111229:172936.126 2b45da947000-2b45da948000 rw-p 00005000 fd:04 625256 /usr/lib64/libgdbm.so.2.0.0
27626:20111229:172936.126 2b45da948000-2b45da9b7000 r-xp 00000000 fd:04 625242 /usr/lib64/libgcrypt.so.11.5.2
27626:20111229:172936.126 2b45da9b7000-2b45dabb6000 ---p 0006f000 fd:04 625242 /usr/lib64/libgcrypt.so.11.5.2
27626:20111229:172936.126 2b45dabb6000-2b45dabba000 rw-p 0006e000 fd:04 625242 /usr/lib64/libgcrypt.so.11.5.2
27626:20111229:172936.126 2b45dabba000-2b45dabbd000 r-xp 00000000 fd:04 625241 /usr/lib64/libgpg-error.so.0.3.0
27626:20111229:172936.126 2b45dabbd000-2b45dadbc000 ---p 00003000 fd:04 625241 /usr/lib64/libgpg-error.so.0.3.0
27626:20111229:172936.126 2b45dadbc000-2b45dadbd000 rw-p 00002000 fd:04 625241 /usr/lib64/libgpg-error.so.0.3.0
27626:20111229:172936.126 2b45dadbd000-2b45dadbe000 rw-p 2b45dadbd000 00:00 0
27626:20111229:172936.126 2b45dadbe000-2b45dadf9000 r-xp 00000000 fd:00 655561 /lib64/libsepol.so.1
27626:20111229:172936.126 2b45dadf9000-2b45daff9000 ---p 0003b000 fd:00 655561 /lib64/libsepol.so.1
27626:20111229:172936.126 2b45daff9000-2b45daffa000 rw-p 0003b000 fd:00 655561 /lib64/libsepol.so.1
27626:20111229:172936.126 2b45daffa000-2b45db008000 rw-p 2b45daffa000 00:00 0
27626:20111229:172936.126 2b45db010000-2b45db01a000 r-xp 00000000 fd:00 655387 /lib64/libnss_files-2.5.so
27626:20111229:172936.126 2b45db01a000-2b45db219000 ---p 0000a000 fd:00 655387 /lib64/libnss_files-2.5.so
27626:20111229:172936.126 2b45db219000-2b45db21a000 r--p 00009000 fd:00 655387 /lib64/libnss_files-2.5.so
27626:20111229:172936.126 2b45db21a000-2b45db21b000 rw-p 0000a000 fd:00 655387 /lib64/libnss_files-2.5.so
27626:20111229:172936.126 2b45db21b000-2b45dba24000 rw-s 00000000 00:09 26476554 /SYSV680083bc (deleted)
27626:20111229:172936.126 2b45dba24000-2b45dca25000 rw-s 00000000 00:09 26509330 /SYSV780083bc (deleted)
27626:20111229:172936.126 2b45dca25000-2b45dce26000 rw-s 00000000 00:09 26542099 /SYSV740083bc (deleted)
27626:20111229:172936.126 2b45dce26000-2b45de95a000 rw-s 00000000 00:09 26574868 /SYSV670083bc (deleted)
27626:20111229:172936.126 2b45de95a000-2b45dee27000 rw-s 00000000 00:09 26607637 /SYSV730083bc (deleted)
27626:20111229:172936.126 2b45dee27000-2b45dee29000 rw-s 00000000 00:09 26640406 /SYSV530083bc (deleted)
27626:20111229:172936.126 7fff4138a000-7fff413b1000 rw-p 7ffffffd7000 00:00 0 [stack]
27626:20111229:172936.127 7fff413db000-7fff413df000 r-xp 7fff413db000 00:00 0 [vdso]
27626:20111229:172936.127 ffffffffff600000-ffffffffffe00000 ---p 00000000 00:00 0 [vsyscall]
27626:20111229:172936.127 ================================
27626:20111229:172936.127 Please consider attaching a disassembly listing to your bug report.
27626:20111229:172936.127 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
27599:20111229:172936.128 One child process died (PID:27626,exitcode/signal:255). Exiting ...
27599:20111229:172938.133 Syncing history data...
27599:20111229:172938.133 Syncing history data... done.
27599:20111229:172938.133 Syncing trends data...
27599:20111229:172938.134 Syncing trends data... done.
27599:20111229:172938.134 Zabbix Server stopped. Zabbix 1.8.7 (revision 21394).
nil)]. Crashing ...27626:20111229:172936.123 ====== Fatal information: ======
