Problems hosts servers : Connection Refused
  • malik
    • Jan 2012
    • 26
    I have problems with servers, they are not monitoring, the icon Zabbix is not green, why ? (I use a zabbix proxy)
    I have others servers (using zabbix proxy) , they are OK.
    I compared zabbix_agentd.conf files of OK server and NO OK, I not seeing problems
    Can you help me please !
    Info : Sorry for my english, I'm french and I wasn't the best student in college
    Best regards,
    Malik.
  • mbrijun
    • Mar 2006
    • 63
    The Zabbix server has to be able to access the agents on port 10050/TCP. The agents have to be able to access the server on port 10051/TCP. If you are monitoring Windows 2008 hosts, you will need to create an inbound rule on the Windows Firewall to allow traffic in from the Zabbix server on port 10050/TCP.
    You can always check the connections by using simple telnet commands
    from the server:
    telnet ip_of_failing_client 10050
    from the failing client:
    telnet ip_of_the_server 10051
    • malik
      • Jan 2012
      • 26
      Yes, telnet commands are OK from server and from host.
      Others Solutions ?
      Zabbix icon is not red or green, I guess the server Zabbix not trying to connect!
      Thank you for your help.
      Malik
