Zabbix Server Log Entry NOT OK
  • kollymars
    • Nov 2011
    One of my child node log files is showing the following entries every time that it send to the master. The master's log file shows no errors.
    6306:20120113:175031.688 NODE 2: Sending history_sync of node 2 to node 1 datalen 9707
    6306:20120113:175032.258 NODE 2: Sending history_uint_sync of node 2 to node 1 datalen 4245
    6306:20120113:175032.579 NODE 2: Sending history_str_sync of node 2 to node 1 datalen 284
    6306:20120113:175032.986 NODE 2: Sending events of node 2 to node 1 datalen 510018
    6306:20120113:175033.812 NOT OK
    The NOT OK entry is weird. Any one seen this?
  • harmonica
    • Jan 2009
    • 251
    I,
    One of my child node log files is showing the same entrie NOT OK.
    Can anyone give an opinion which may cause this?
    Regards
    • harmonica
      • Jan 2009
      • 251
      I,
      I have 1 master and 3 childs and still having trouble on two child nodes, causing the events are not to be synchronized to master. The log entry is the same.
      Node 3:
      30955:20120412:120700.144 NODE 3: Sending history_sync of node 3 to node 1 datalen 197
      30955:20120412:120701.525 NODE 3: Sending events of node 3 to node 1 datalen 19806
      30955:20120412:120702.017 NOT OK
      30955:20120412:120709.445 NODE 3: Sending history_sync of node 3 to node 1 datalen 342
      30955:20120412:120710.246 NODE 3: Sending history_uint_sync of node 3 to node 1 datalen 145
      30955:20120412:120711.495 NODE 3: Sending events of node 3 to node 1 datalen 19806
      30955:20120412:120711.974 NOT OK
      Node 2:
      27060:20120412:121813.793 NODE 2: Sending history_sync of node 2 to node 1 datalen 342
      27060:20120412:121814.061 NODE 2: Sending history_uint_sync of node 2 to node 1 datalen 232
      27060:20120412:121815.140 NODE 2: Sending events of node 2 to node 1 datalen 133077
      27060:20120412:121815.622 NOT OK
      27060:20120412:121823.950 NODE 2: Sending history_sync of node 2 to node 1 datalen 488
      27060:20120412:121824.283 NODE 2: Sending history_uint_sync of node 2 to node 1 datalen 468
      27060:20120412:121826.121 NODE 2: Sending events of node 2 to node 1 datalen 133077
      27060:20120412:121826.603 NOT OK
      Does anyone have an opinion on what may cause this situation?
      Regards
      • pearlboone78
        • Apr 2012
        Found you! Having the same problem as well. I'll try the solutions here and see if I get the same result as you have.
        WhiteMica
        SCTR
        • harmonica
          • Jan 2009
          • 251
          I,
          The solution for me was: https://support.zabbix.com/browse/ZBX-3996
