I've been using Web scenario step for some time now with no issues, suddenly today for some reason, most of the web checks are coming back with:
and sometimes I found this in the logs:
When I restart the zabbix process (
), all web scenario running successfully again, but shortly after (~ 24 hours later), they fall back again with the same errors.
I tried to increase the "Timeout" variable in the /etc/zabbix/zabbix_server.conf file (Default Timeout=3 by Timeout=20), but this does not solve the problem!
I've checked and the server can both look up the IP address from the name, and i can use curl to get the webpage, both using http:// and not using http://. However in the web checks i'm getting the errors!
Nothing has changed on the server, so I'm pretty confused as to where the error is coming from!
OS Configuration:
Ubuntu Server 10.04.3 LTS (Virtual machine ESXi 4.1.0)
Zabbix 1.8.5
8 GB RAM
Virtuals processors: 4
mysql-server 5.1.41
Thanks in advance for your help!
Web scenario step [1 of 1] error: error doing curl_easy_perform: Couldn't resolve host name
Web scenario step [1 of 1] error: error doing curl_easy_perform: Timeout was reached
/etc/init.d/zabbix_server stop; /etc/init.d/zabbix_agent stop; sleep 2; /etc/init.d/zabbix_server start; /etc/init.d/zabbix_agent start
OS Configuration:
Zabbix 1.8.5
8 GB RAM
mysql-server 5.1.41
