Hy,
I have a problem regarding external checks.
I wrote a little shell script the gets the software version number of a device.
When I execute the script manually it works fine, also with zabbix user.
But when I create an item for this, it became not supported because script returned no value.
If I enable the last line and echo the version number in that way it also works in zabbix.
I also tried once to read the version number in a variable and echo this variable, but was the same problem. Why does it work when I echo a hardcoded value.
Hope anybody can help me.
UPDATE: there must be some problem with reading from files, but no idea why.
br
#!/bin/sh #writes the sw version number in the file "sw_version" ./get_webio_sw_version.sh #print the sw version tail sw_version #delete temp files rm -f sw_version rm -f httpresponse #debug #echo 2.26
br
