icmpping trigger
  • chaouki
    • Nov 2011
    • 10
    icmpping trigger
    Hello everyone,
    I have a problem with icmpping trigger.
    I can not create an expression that allows me to initiate a trigger when a host does not respond to ICMP requests more than 2 times. It should not be alert if there is only one icmp packet loss.
    my item is configured:
    Description : Ping to the server (TCP)
    Key : icmpping
    Interval : 60
    Type : Simple check
    Here's my attempt at expression:
    - {equipement:icmpping.sum(#2)}= 0 & {equipement:icmpping.last(0)}> 2
    - {equipement:icmpping.sum(#5)}=2
    - {equipement:icmpping.last(0)}=2
    - {equipement:icmpping.last(0)} > 2
    Thank you very much for your help.
    Regards,
    chaouki.
  • trikke
    • Aug 2007
    • 140
    try count(#3,0)}>2 --> more than 2 out of the 3 last values!
    Greets
    Patrick
    • chaouki
      • Nov 2011
      • 10
      Thank you for your proposed solution.
      I managed with the following expression:
      equipement:icmpping.sum(#2)}=0 | ({TRIGGER.VALUE}=1 &{equipement:icmpping.sum(#5)}#5)
      But I'm stuck in another case:
      I want to create a trigger when I get five consecutive negative responses. The alarm works well but it creates a second and third and so on.
      Equipment: icmpping.sum (#5)=0} | ({} = 1 & TRIGGER.VALUE {equipment: icmpping.sum (# 5)} # 5)
      Do you know how to configure receive only one that increments?
      Thanks !
