latest vmware appliance failure package
  • mandragora
    • Sep 2009
    • 14
    Hi all
    I´ve downloaded the latest vmware appliance.
    I have the tar.gz file on my computer and when i want unzip the folder i get an error message that the file is damaged.
    into the tar.gz file are a file namend "rOra"
    i´ve downloaded the file three times more also on other computers and always the same failure.
    does anybody know what?s happend ?
    thank you very much
    cu
    mandragora
  • mandragora
    • Sep 2009
    • 14
    hi it`s me again,
    Does nobody have this issue ?
    i have downloaded from different sources and on all files the same failure.
    can anybody check this please.
    thank you very much
    best regards
    mandragora
    • mandragora
      • Sep 2009
      • 14
      hmmm nobody have this problem ?
      • twarnick
        • Sep 2004
        I have the same problem.
        i try different format also
        • mandragora
          • Sep 2009
          • 14
          Hi twarnik.
          i have the solution for this problem.
          i use Izarc as package manager and i get this failure.
          with winrar it woud work perfectly.
          i hope this helps.
          cu
          mandragora
