Web monitoring test login problem
  • trazodone
    • Feb 2012
    I have a problem on web monitoring scenario step. I followed Zabbix user's manual. In web scenario login step I use command
    "user={user}&password={password}&enter=Enter"
    This command success login on localhost(zabbix) but when I try on other host it is not success. I am wondering on "enter=Enter" it came from html source code of Zabbix login page as
    "<input type="submit" name="enter" id="enter" class="button" value="Enter"/>"
    I understood that "id=value" and became "enter=Enter"
    On my other login page is
    "<input type="submit" class="button" value="Login" name="submit"/>"
    There is no "id" so I tried many condition such as
    submit=Login
    submit=Enter
    enter=Enter
    But all of these not working.
    The question is what should I do to create web scenario login with kind of web page that has no "id" on button object?
    Thank you very much.
  • Andrius
    • Sep 2013
    I have the same problem!
    On my login page is
    <input class="button" name="submit" accesskey="l" value="Connect" tabindex="4" type="submit" />
    What should I do to create web scenario login with kind of web page that has no "id" on button object? What should I write instead "enter = Enter"
    Thank you very much!
    • pinarella
      • May 2013
      • 16
      name="submit"
      grab this one
      submit=Enter
      • jeetusjeet
        • Oct 2014
        • 13
        I understand the above step configuration for login step, but what should be in logging in step and logout step specified in real scenario?
        Some web application asks confirmation ("Are you sure want to log out"). How to deal with this?
        • BDiE8VNy
          • Apr 2010
          • 680
          I suggest to trace the GET/POST request as well as their response/output while manually doing the desired scenario with your Internet browser.
          Then you can identify the necessary requests and potentially needed parameters to define a Zabbix web scenario.
          My personal favorite Firefox add-on to do this is HttpFox.
          • jeetusjeet
            • Oct 2014
            • 13
            Unable to understand what should be use to configure Login step for Web scenario
            I am trying to configure Web monitoring for one of my web app. As per documentation, for Step 2 (Logging in), i am unable to find out what should be used in POST & variable. I used the below command to get some output using curl:
            curl -v \
            > --data 'ctl00$ContentPlaceHolder1$txtUserName=XXXX&ctl00$ ContentPlaceHolder1$TxtPassword=XXXX&ctl00$Content PlaceHolder1$btnLogIn=Sign In' \http://cabletvcrm.com/UserInterface1/SignIn.aspx
            And attached file is the output i got.
            Could someone please help me out on this.
            Thanks,
            Jitendra
