I have a zabbix server at 192.168.10.2 and its db is hosted on a different server, 192.168.10.3
Everything works as expected BESIDES when using a zabbix_sender.
You can see in the logs that the zabbix server/trapper gets the correct data but fails to process it. I think i have it troubleshot down to it not likeing the remote database. I pointed the zabbix server to the localdatabase, created a quick host with an item (zabbix trapper) and the zabbix_sender works fine.
I'm not 100% sure this is the problem, but all signs point to yes. When using a remote db for a zabbix server, when using a zabbix_sender command to the server, it fails to process.
response is much appreciated. I'm using zabbix 1.8.10 but seems to be that way as i reverted to 1.8.5 and had the same issues (server and agent as the agent is was updates the zabbix_sender)
I can give more details if needed, but remote db to me is the problem (like the trapper on the zabbix server is looking at the localdatbase and not the DBHost=192.168.10.3 parameter in the conf file.)
