I have been using zabbix 1.8.2 for the last year and thought it would great to update to version 1.8.10. I use ubuntu's apt-get install to install the zabbix dependencies.
In 1.8.2 to add new MIBS I had to to add the text file to /usr/share/snmp/mibs/ and restart the zabbix-server to be able to get the items to report a value.
Since updating to 1.8.10 I can't get my new MIBs to work. The pre-load templates works not my new MIBs.
I get the following message from the logs (/var/log/zabbix-server/zabbix_server.log)
snmp_build: unknown failure 1703:20120209:093959.502 Item [vladimir:vibeCallsBlocked[colla type]] error: Cannot find index [vibePeerName] of the OID
[VOIPEX-VIBE-MIB::vibeCallsBlocked["index","vibePeerName","colla type"]]: SNMP error [1]
1692:20120209:094000.873 Item [tvn01-os01:sensor[temp1]] error: Not supported by Zabbix Agent
snmp_build: unknown failure 1692:20120209:094000.886 Item [vladimir:vibeRTTAverage[colla type]] error: Cannot find index [vibePeerName] of the OID [V
OIPEX-VIBE-MIB::vibeRTTAverage["index","vibePeerName","colla type"]]: SNMP error [1]
1693:20120209:094001.394 Item [tvn01-os01:sensor[temp2]] error: Not supported by Zabbix Agent
snmp_build: unknown failure 1693:20120209:094001.407 Item [vladimir:vibeRXJitterAverage[colla type]] error: Cannot find index [vibePeerName] of the O
ID [VOIPEX-VIBE-MIB::vibeRXJitterAverage["index","vibePeerName","colla type"]]: SNMP error [1]
snmp_build: unknown failure 1694:20120209:094002.084 Item [vladimir:vibeTXJitterAverage[colla type]] error: Cannot find index [vibePeerName] of the O
ID [VOIPEX-VIBE-MIB::vibeTXJitterAverage["index","vibePeerName","colla type"]]: SNMP error [1]
I tried research snmp_build but I am not completely sure what it does.
Any help or comments on the above is much appreciated.
Thanks,
Thanks,
