Zabbix 1.8.6 API screen.delete permission failure
  • tool
    • Apr 2011
    Hi gyus.
    I try to work with ruby [https://github.com/verm666] libs for Zabbix api, but sinse 1.8.6 there are some changes in API i modify some defs, and i have a problem with Deleting screen, in 1.8.4 i can simple remove all graphs from screen, now i need to delete screen, and create new screen which i populate with graps [Thx for it ] anyway in def del_all_graphs_from_screen(screen_id)
    i remake message to this:
    ······message = {
    ········'method' => 'screen.delete',
    ········'params' => {
    ··········'screenids' => [ screen_id ]
    so i try to send screen.delete using my api user (it's working for all other operations, mass link template (also hellobug https://support.zabbix.com/browse/ZBX-3589), get templates and oth) but i received error
    Zabbix::ResponseError: Code: [-32500]. Message: [Application error.]. Data: [[ CScreen::delete ] You do not have permission to perform this operation].
    I'm not php pro, i think there are some eror in API class, maybe someone can help me with this API method error?
