Monitor own disk space
  • Niven
    • Apr 2005
    • 20
    Hi
    I'm trying to set Zabbix up to monitor its own disk space. I'm running zabbix_agentd to do this. when i run PS -A i cant see a proccess for it.
    I'm unable to get any data for the disk space. Are there any problems running it at the same time as zabbix_server.
    Zabbix_agentd.log is empty and a pid file is created.
    I have 1.1beta8
    Regards
    Nielsen
  • krusty
    • Oct 2005
    • 222
    Hi, what happens when you start the agent?
    /usr/local/bin/zabbix_agentd
    You wrote that the pid file is still created. Then you have to remove the file manually and restart the agentd. Do you checked the /etc/zabbix/zabbix_agentd.conf file. Does the directory exists which is needed from the config file? (for example /home/zabbix/tmp/)
    Does the directory have had the right permission?
    • Niven
      • Apr 2005
      • 20
      When i start the agent it creates /var/tmp/zabbix_agentd.pid
      I pressume this is the location you're talking about.
      The only two paths in the zabbix_agentd.conf are /var/tmp/zabbix_agentd.pid and /tmp/zabbix_agentd.log
      • krusty
        • Oct 2005
        • 222
        Will the log file created? Whats the topic of the file? Any errors?
        • Niven
          • Apr 2005
          • 20
          Log File is empty.
          • Niven
            • Apr 2005
            • 20
            I appear to have fixed it by changing a few bits in zabbix_agentd.conf
            I changed to a different listening port and set the hostname to 127.0.0.1
            zabbix_agentd is now running and data is collected
