graphs display problem
  • patrick
    • Oct 2004
    • 57
    I'm using zabbix 1.1beta7 (Linux Fedora Core 4). Everything seems to be OK but I can't see graphs. I only have a "broken" Icon like if the graph doesn't exist.
    If I do a "viewimage" on the icon (right click) I have the error "~zabbix/chart2.php?graphid=......cannot be displayed, because it contains errors"
    What could be the problem?
  • zixel
    • Apr 2006
    go over the requirements for zabbix and make sure that php has gd2 support and is configured correctly (php.ini).
    • elkor
      • Jul 2005
      • 299
      aye, also search the forum.
      this has been gone over many many times in the past and a simple search on graphs and problem should give you tons of things to try
      • lofouk
        • Feb 2006
        • 14
        you need to desinstall PHP and reinstall with the latest version
        it should work
