Sync problem
  • joedson
    • Jul 2011
    • 19
    Sync problem
    I have a DM setup with one master and 4 children. Child's alerts never show up in the 'last 20 events' list. Even is I switch 'current node' to the child node, they don't show up either.
    Even with all history been completely sync, I can't see any event sync at log.
    Any idea how to solve it?
    PS:
    All Zabbix has the same version version:
    Zabbix Server v1.8.9 (revision 23398) (22 November 2011)
    Compilation time: Jan 18 2012 10:33:47
    And all zabbix the file /etc/zabbix/zabbix_server has: "NodeNoEvents"
    setup to 0.
    Thanks!
  • RobertS
    • Aug 2006
    • 57
    Problem found!
    the log of the child node should have entries like:
    5517:20120228:092218.376 NODE 1: Sending events of node 1 to node 999 datalen 510018
    If this entry is followed by a
    5517:20120228:092218.843 NOT OK
    then event sync is not working anymore.
    I posted this problem in already in 2009 (http://www.zabbix.com/forum/showthread.php?t=14292) but unfortunately never got an answer. But I found several other posts from people having similar problems.
    So after years I tried to set up DM again and as it is still not working in my environment I tried to investigate the reason and thanks to DEBUG LEVEL 4 I hope I found it: There is simply the trigger missing for the event and then the whole process fails. You can investigate have an erroneous entry in executing the following query:
    SELECT * FROM events LEFT JOIN triggers ON events.objectid = triggers.triggerid WHERE (((events.source)=0) AND ((events.object)=0) AND ((triggers.triggerid) Is Null));
    You can delete the entry in the events table and replication will work.
    I enclosed the debug log. Perhaps anybody can fix this long lasting bug!
    Regards,
    Robert
    • RobertS
      • Aug 2006
      • 57
      OK, if I had first a looked at the tracker I would not need to debug:
