Action oddness
  • elkor
    • Jul 2005
    • 299
    Action oddness
    OK, maybe I'm missing something here, as I did a search and I did not see anyone else really complaining about it.
    I just did a b1 to b8 upgrade and got everything running. I am now dealing with the syntax changes and new way that actions work.
    I like the new actions, it should really allow me to reduce the number of entries there.
    BUT
    host group doesn't seem to work?
    example:
    I have 2 actions configured
    1st with conditions: host = Ix
    2nd with conditions: host group = Mail Gateways, Trigger Severity <> Information
    Both actions are enabled
    Ix is not a member of Mail Gateways and I has 1 item/trigger defined that chksums inetd.conf with a severity of average.
    NOW, when I change inetd.conf I get 4 alerts, 2 on 2 off.
    This shouldn't happen because the second action should be ignored (Ix is not a member of Mail Gateways) but it isn't. This led me to believe that the conditions list was performing a logical OR instead of an AND, so I added a third condition
    trigger value = ON
    after adding this and rerunning the test I get 3 mail messages, an on and an off from alert 1, and a single on from alert 2.
    This just doesn't make sense! if the conditions were an OR then I would still get 4 alerts (because of the trigger severity condition), I don't understand how the action conditions effect the executions of actions (unless it's a bug)
    can anybody shed a little light on this scenario or run a test themselves? please?
  • elkor
    • Jul 2005
    • 299
    OK,
    I think I may have figured out what is wrong here. And I believe it's a bug.
    Ix was not in ANY of my configured host groups, when I added it to the web servers one, the erroneous alert from trigger 2 ceased. it looks like the above problem will occur if your action is based on host groups and a host who is not a member of any group encounters an issue.
    This means that if your actions are configured in this way, and a "lone" host lights up a trigger, you will get an email (or remote action!!!!! ) for every alert that is configured to fire based on host group membership.
    I would still like some independent verification of this if possible, I am running 1.1beta8 on the server side; so if either Alexei or someone else with a testbed could chime in and let me know I'm not crazy it would be appreciated
    • elkor
      • Jul 2005
      • 299
      another potential problem:
      I really really do not want to scrap a beta8 rollout here over this.
