Hello Guys,
I have the following scenario in DM:
The master node which dosen't monitor
nothing, it just serves as a DB concenter;
And four slaves nodes, with this scenario
evething is working fine.
But when I try add any new node the
Master node just stop receiving update
from the all slaves nodes.
Obs: The application "htop" indicates the full use
of ram, e almost 1Gb of use of swap memory.
PS: The of Master node following configuration is:
4Gb of Ram
Cpu: Intel(R) Xeon(R) CPU E31220 @ 3.10GHz with four cores
Database: Mysql
Zabbix Server v1.8.9 (revision 23398) (22 November 2011)
Compilation time: Jan 18 2012 10:33:47
Thanks!
4Gb of Ram
Database: Mysql
Thanks!
