We are monitoring over 500 hosts spread across several sites geographically (using zabbix proxies at each site).
The alerter process for Zabbix will often spike to 100% busy for a minute or two, but calm back down. It has progressively gotten worse, to the point where the process was busy (100%) for a couple days at a time, causing Zabbix to fail to connect to monitored hosts and throwing many false alarms. Postgresql also has a very hard time when this happens.
I have observed the logs and don't see any correlation with the spikes. When I attach an strace to the pid, I see a lot of:
Is there a way to start multiple Alerter processes to share the load? What do we need in order to prevent this from happening?
select(0, NULL, NULL, NULL, {0, 100000}) = 0 (Timeout)
read(4, 0x289a9e3, 5) = -1 EAGAIN (Resource temporarily unavailable)
