Problem with active agents
  • gottberg
    • Mar 2012
    Hi, ive been searhing for an answer for this problem but i havent found any solution yet. I have 3 hosts im trying to monitor but im getting a
    Get value from agent failed: *** Cannot connect to []:0 [Interrupted system call] on all the hosts.
    I can monitor and see their data etc. NOTE the agents are active because ports cannot be opened due to security reasons.
    I have another problem too, im using the Linux template but it cant find syslogd running, what should i change in the template item?
    Best regards
    Simon
