Hi ,
im facing a problem and i figure out what is the problem and solution but cant find what is the cause of it.
The problem is in data being syncronize from proxies to zabbix_server. In our network we have 2500 proxies and from time to time we find that data in some proxies are outdate but hosts being monitored are up.
Everything is correctly configure but no data tranfer to server.
Looking closer in proxy database i found that the nextid in ids table is much bigger than the last id in the proxy_history table.
With this proxy think than all the data has been syncronized and no new data is transfer.
Solution setting the nextid with a number close to the last in the proxy_history.
I dont know if houskeeping clear every data and the id start from 1 again. I guess...
With all the proxies we have this is really laborious to solve. I am thinking to workaround this with a scrip in each proxy or a remoe command in zabbix_server.
Someone can give me a clue of the problem im facing. Or a simplier solution way.
Thanks to all
Thanks to all
