Hi, I am getting the below messages when trying to integrate an external script into zabbix
scp timed out while trying to connect to x.x.x.x at /etc/zabbix/externalscripts/scp-check.pl line 41
22218:20120312:062959 Script /etc/zabbix/externalscripts/scp-check.pl returned nothing.
22218:20120312:062959 Parameter [scp-check.pl[--file configure]] is not supported by agent on host [router1] Old status [0]
I am able to run the script from the command line. Any idea as to why "Not Supported" is showing up in the zabbix logs ?. The Item changes it status to "Not Supported" by itself.
Thanks,
Viks
Thanks,
Viks
