How can I determine how many values per second my zabbix
server is capable of ?
Used cpu+load are less than 1%, used memory also very low.
I am careful to only monitor what I need to and disable unrequired checks.
I also make the polling intervals as long as possible (yet remain useful)
Backend Zabbix is a separate DB server Raid10.
Frontend Zabbix is a VM.
Zabbix server is running Yes 192.168.10.10:10051
Number of hosts (monitored/not monitored/templates)
121 85 / 1 / 35
Number of items (monitored/disabled/not supported)
20189 10016 / 9508 / 665
Number of triggers (enabled/disabled)[problem/unknown/ok]
1506 1337 / 169 [60 / 131 / 1146]
Number of users (online) 3 1
Required server performance, new values per second 70.3
121 85 / 1 / 35
