Ssh checks
  • zabbixflic
    • Jan 2012
    • 39
    Ssh checks
    Hi people,
    I configured an Ssh Check in order to login on a unix server (in SecureCrt
    it shows me a pop-up to accept and store new host key fingerprint
    and so I must enter login and password info).
    I put no parameters cause I want this item is useful to every host;
    then when I fired item I got this error
    "support for ssh checks was not compiled in"
    Thank you for help !
    bye
  • harmonica
    • Jan 2009
    • 251
    I,
    There are some requirements for SSH support. You should install libssh2 and compile --with-ssh2.
    Example:
    ./configure --enable-server --enable-agent --with-mysql --with-net-snmp --with-jabber --with-libcurl --with-ldap --with-ssh2
    • zabbixflic
      • Jan 2012
      • 39
      Originally posted by harmonica
      I,
      Example:
      Ok,
      now I run (Ubuntu)
      apt-get install libssh2-php
      where can I find "configure" ?
      many thanks!
      • harmonica
        • Jan 2009
        • 251
        I,
        In the installation process. Take a look at Step 4 in manual.
        http://www.zabbix.com/documentation/...on_from_source
        • zabbixflic
          • Jan 2012
          • 39
          I,
          mhmm... any other way to get it running post-installation ?
          my Zabbix server is running since 2 months.. and it is in pre-production
          state
          thank you
          • zabbixflic
            • Jan 2012
            • 39
            Hi people,
            sure no way to enable ssh check post-installation ?
            thanks !
            bye
            • zabbixflic
              • Jan 2012
              • 39
              Have I to give up ?
              thanks
              • harri
                • Nov 2010
                • 89
                AFAICS the Zabbix packages for Ubuntu are configured with "--with-ssh2" since version 1:1.8.4-3. Please check the output of "dpkg -l 'zabbix*' " to verify the version installed on your server.
                Maybe you should consider an upgrade?
                • zabbixflic
                  • Jan 2012
                  • 39
                  Hi harri,
                  unfortunately this is my output
                  "No packages found matching zabbix*."
                  I think this is why I used this guide :
                  http://www.zabbix.com/wiki/howto/ins.../ubuntuinstall
                  Of course, package in the Ubuntu repository was an old version so I proceed
                  in that way.
                  So, how can I go on now ?
                  Thanks!!
                  • harri
                    • Nov 2010
                    • 89
                    If you prefer to build Zabbix on your own, then you have to rebuild it now using the additional option "--with-ssh2", as Zabbixflic wrote a few postings ago.
                    • zabbixflic
                      • Jan 2012
                      • 39
                      Hi harri,
                      considering Zabbix "environment" is in production,
                      what will I loose rebuilding from source ?
                      Could you give me some hints in order to backup or avoid problems ?
                      Many thanks again
                      bye!
