Hi, is there going to be support for win 2003 servers .....?
Win 2003
Already supported!
ZABBIX Win32 agent already works under Windows 2003. -
Please, search forums (both zabbix.com and Sourceforge). Issues with 2003 were discussed several times.
Check if port 10000 is not taken by some other software (Veritas Backup?).Comment
Somehow Zabbix Agent is slow when it is configured to start automatically at startup. Most of the time Windows will complain that it stops responding. But finally it will start and running normally. But somehow the startup is not slow at all if it is manually started from the Service applet.Originally posted by HugoI Tryed it on one of our 2003 servers and it wouldn't start. It gave a problem
like it took to long to start.
Please advice, ThanksComment
Originally posted by mcyipSomehow Zabbix Agent is slow when it is configured to start automatically at startup. Most of the time Windows will complain that it stops responding. But finally it will start and running normally. But somehow the startup is not slow at all if it is manually started from the Service applet.
I get this exact same behavior, windows 2000, 2003, server, advanced server, etc
