Hello dear Community
Lately I discovered zabbix and I am very impressed.
Immediately I'll started using
My First Server to Monitor is a local machine.
Zabbix is installed on a Linux Machine(suse). I Monitor a Windows Server 2003 with the zabbix agent.
It was simple, I installed the agent on the Windows Machine and made the config file. Then I'll added the Windows Server to the zabbix system(webUI).
It just works fine.
So now I want to monitor this Server through sender. Again I'll installed the sender.
But now I don't know where or how to configure this server in zabbix(in the webUI).
I think, the standard configuration window in zabbix is for agents and not for sender.
Here is a picture where I'll configured the machine in zabbix:
Anyway I can't even find the right part in the manual to get it work. Bottomline I want to monitor this machine through sender. The machine should send the information to the zabbix server.
Help, How can I get there?
.My First Server to Monitor is a local machine.
It just works fine.
