connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'local
  • lingan
    • Mar 2012
    wondering if someone can help me, i was installed the zabbix and configured in rhel5.
    zabbix_server
    zabbix_agentd
    httpd are up and running
    but in
    zabbix server log
    I got an error
    5155:20120401:204322.988 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: YES)
    5155:20120401:204322.988 Database is down. Reconnecting in 10 seconds.
    5155:20120401:204332.989 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: YES)
    5155:20120401:204332.989 Database is down. Reconnecting in 10 seconds
  • marcelotada
    • Dec 2011
    • 31
    Try this:
    GRANT ALL PRIVILEGES ON *.* TO zabbix@localhost IDENTIFIED BY 'zabbix-password'
    P.s.: the password must be between quotes.
    • lingan
      • Mar 2012
      Dear,
      Thanks for you update,I have install and configure
      and now iam able to access the zabbix in browser.
      please find the my attachemnts for linux and windows agentd logs
      FOR LINUX AGENT LOGS
      2728:20120403:215610.507 One child process died (PID:2734,exitcode/signal:255). Exiting ...
      2728:20120403:215612.508 Zabbix Agent stopped. Zabbix 1.8.11 (revision 26205).
      25425:20120403:215630.885 Starting Zabbix Agent [Zabbix server]. Zabbix 1.8.11 (revision 26205).
      25426:20120403:215630.886 agent #0 started [collector]
      25428:20120403:215630.888 agent #1 started[listener]
      25429:20120403:215630.888 agent #2 started[listener]
      25430:20120403:215630.888 agent #3 started[listener]
      25431:20120403:215630.889 agent #4 started [active checks]
      FOR WINDOWS LOG
      1452:20120403:212828.662 Zabbix Agent stopped. Zabbix 1.8.11 (revision 26203).
      2680:20120403:214818.498 Starting Zabbix Agent [zabbix server]. Zabbix 1.8.11 (revision 26203).
      2696:20120403:214818.529 agent #1 started[listener]
      2704:20120403:214818.529 agent #3 started[listener]
      2692:20120403:214818.529 agent #0 started [collector]
      2700:20120403:214818.529 agent #2 started[listener]
      2708:20120403:214818.529 agent #4 started [active checks]
      I have some questions
      IS it possible zabbix server in linux and agent in windows ?
      Where to modify the parameters?
      Is anything edit in GUI?
      Please let me know .................
      Please help me where to update i am really appreciate u.
      • marcelotada
        • Dec 2011
        • 31
        Take a look at zabbix download page. There are agents to many platforms.
        http://www.zabbix.com/download.php
        • lingan
          • Mar 2012
          Dear,
          I have downloaded the agent from what you given the link from that website and installed and it showing started i have attached the logs also
          But my question is simple..
          agent is sending the info to zabbix server or not.........I am very new for the zabbix one...
          Please let me know..........
          • lingan
            • Mar 2012
            I have installed the agentd in windows 32 bit,I am getting this below error please help me to resolve.
            6196:20120405:193916.477 listener failed: bind() for [[$ $ $ $]:10050] failed: [0x00002741] The requested address is not valid in its context.
