Zabbix says apache or mysql is not running
  • fabWeb
    • Apr 2012
    • 9
    Zabbix-agent is ok on the host, and mysql and apache online but Zabbix-server says apache or mysql is not running
    I change “proc.num[httpd]” to “proc.num[apache2]“ into item but nothing...
    Any ideas please ?
  • fabWeb
    • Apr 2012
    • 9
    the security path grsecurity block access to proc ?
    • anoriel
      • Apr 2012
      Hi all,
      I have the same issue on a debian squeeze...
      I don't understand why...
      Did you find how to solve this problem?
      • fabWeb
        • Apr 2012
        • 9
        Originally posted by anoriel
        Hi all,
        not really...
        lookup up to zabbix page http://www.zabbix.com/documentation/...l/config/items :
        Linux-specific note. Zabbix agent must have read-only access to filesystem /proc. Kernel patches from www.grsecurity.org limit access rights of non-privileged users.
        • gobbetto
          • May 2012
          I have the same problem on two Debian squeeze (6.0.5) servers: Zabbix says apache, mysql, inedtd, syslogd, sshd are not running on the servers...
          grsecurity kernel patch is not installed.
          Any idea?
          thank you in advance...
          • TURIST
            • May 2012
            Any idea?
            Okay. I found the reason for message about Apache.
            Solution:
            Just go to Configuration -> Templates, then to Template Linux & Items.
            Change for Item "Number of running processes apache" in the key httpd to apache2 (so new value is proc.num[apache2]).
            Reason:
            In Debian/Ubuntu the process for apache instance is named apache2.
            I guess the same fixes are required for others keys when processes are named differently in different OS (Debian, Ubunty, CentOs...).
            • gobbetto
              • May 2012
              Thank you very much, very helpful and probably you are right, but the problem is still there...
              I have Zabbix 1.8.2, so I do not have Configuration -> Templates menu.
              I used the Import/Export menu under "configuration" to export the Linux template, make the correction and then re-import it.
              I edited the line about Apache this way:
              <expression>{Template_Linuxroc.num[apache2].last(0)}&lt;1</expression>
              but the re-import of the corrected .xml file fails, with this error:
              No such monitored parameter (proc.num[apache2]) for host (Template_Linux)
              Trigger [Apache is not running on {HOSTNAME} ]: cannot create
              Searching in this forum I found that a solution maybe to edit /etc/zabbix/zabbix_agentd.conf and add a user-defined monitored parameter, but, if so, I can't find the right syntax...
