Please help me resolve this error.
Any help is much appreciated
thanks
this is the error
[root@LNDEV02 zabbix-1.1beta7]# make
Making all in src make[1]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src'
Making all in libs make[2]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs' Making all in zbxcommon make[3]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcommon' make[4]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcommon'
make[4]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcrypto'
make[3]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcrypto'
make[3]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxconf' make[4]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxconf' make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxconf'
make[3]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxconf'
Making all in zbxdbhigh make[3]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxdbhigh' make[4]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxdbhigh'
if gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I../../../include -I/usr/local/pgsql/include -g -O2 -MT action.o -MD -MP -MF ".deps/action.Tpo" -c -o action.o action.c; \
then mv -f ".deps/action.Tpo" ".deps/action.Po"; else rm -f ".deps/action.Tpo"; exit 1; fi In file included from action.c:27:
../../../include/db.h:38:23: libpq-fe.h: No such file or directory
In file included from action.c:27: ../../../include/db.h:331: error: syntax error before '*' token
../../../include/db.h:331: warning: data definition has no type or storage class
../../../include/db.h:332: error: syntax error before '*' token
../../../include/db.h:333: error: syntax error before '*' token
../../../include/db.h:361: error: syntax error before "PGresult"
action.c: In function `DBget_action_by_actionid':
action.c:65: error: `PGresult' undeclared (first use in this function)
action.c:65: error: (Each undeclared identifier is reported only once
action.c:65: error: for each function it appears in.)
action.c:65: error: `result' undeclared (first use in this function)
make[4]: *** [action.o] Error 1 make[4]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxdbhigh'
make[3]: *** [all-recursive] Error 1 make[3]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxdbhigh'
-bash: command substitution: line 1: unexpected EOF while looking for matching `'' -bash: command substitution: line 4: syntax error: unexpected end of file
-bash: make[1]:: command not found
[root@LNDEV02 zabbix-1.1beta7]# make[4]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcommon'
> make[4]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcommon'
-bash: command substitution: line 3: syntax error: unexpected end of file
-bash: make[4]:: command not found
[root@LNDEV02 zabbix-1.1beta7]# make[3]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcommon'
> Making all in zbxlog
> make[3]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxlog'
> make[4]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxlog'
-bash: make[3]:: command not found
[root@LNDEV02 zabbix-1.1beta7]# make[4]: Nothing to be done for `all-am'.
> make[4]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxlog'
> make[3]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxlog'
[root@LNDEV02 zabbix-1.1beta7]# Making all in zbxcrypto
-bash: Making: command not found
[root@LNDEV02 zabbix-1.1beta7]# make[3]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcrypto'
> make[4]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcrypto'
[root@LNDEV02 zabbix-1.1beta7]# make[4]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxcrypto'
> Making all in zbxpid
> make[3]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxpid'
[root@LNDEV02 zabbix-1.1beta7]# make[4]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxpid'
> make[4]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxpid'
[root@LNDEV02 zabbix-1.1beta7]# make[3]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxconf'
[root@LNDEV02 zabbix-1.1beta7]# make[4]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxconf'
[root@LNDEV02 zabbix-1.1beta7]# make[4]: Entering directory `/opt/zabbix/zabbix-1.1beta7/src/libs/zbxdbhigh'
-bash: syntax error near unexpected token `('
[root@LNDEV02 zabbix-1.1beta7]# action.c:65: error: (Each undeclared identifier is reported only once
[root@LNDEV02 zabbix-1.1beta7]# action.c:65: error: for each function it appears in.)
-bash: syntax error near unexpected token `)'
[root@LNDEV02 zabbix-1.1beta7]# action.c:65: error: `result' undeclared (first use in this function)
-bash: action.c:65:: command not found
[root@LNDEV02 zabbix-1.1beta7]# make[2]: *** [all-recursive] Error 1
-bash: make[2]:: command not found
[root@LNDEV02 zabbix-1.1beta7]# make[2]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src/libs'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/opt/zabbix/zabbix-1.1beta7/src'
> make: *** [all-recursive] Error 1
thanks
this is the error
