Zabbix 1.8.11 crash when added new Host
  • pazder
    • Aug 2009
    Hi all,
    first I must say, that Zabbix is a great product!
    I have now this problem. I am running Zabbix server 1.8.11 on CentOS 5 (Linux box 2.6.18-194.3.1.el5 #1 SMP Thu May 13 13:08:30 EDT 2010 x
    86_64 x86_64 x86_64 GNU/Linux) using postgres SQL 8.1.11 and have few servers monitored by Zabbix clients. Everything was running properly until I have added new monitored Host running on FreeBSD 8.1, i386 with zabbix client (I have tried different versions of client with no success). When this new host was added, the zabbix server allways crashes. If I disable monitoring of this host, everything works fine. This host was created with modified FreeBSD template, which I also used for other hosts, which are monitored correctly. Below please see the log (complete log attached).
    Thank you very much for help.
    Jan
      7357:20120416:095015.791 In zbx_evaluate_item_functions() ifuncs_num:7
      7357:20120416:095015.791 query [txnlev:1] [select i.itemid,i.key_,h.host,h.port,i.delay,i.description,i.type,h.useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.hostid,i.value_type,i.delta,i.prevorgvalue,i.lastclock,i.units,i.multiplier,i.formula,i.status,i.valuemapid,h.dns,i.trends,i.lastlogsize,i.data_type,i.mtime,h.status from hosts h,items i where i.hostid=h.hostid and i.itemid in (18461,18468,18493,18524,22482,27194,27232)]
      7357:20120416:095015.794 Got signal [signal:11(SIGSEGV),reason:1,refaddr:(nil)]. Crashing ...
      7357:20120416:095015.794 ====== Fatal information: ======
      7357:20120416:095015.794 Program counter: 0x3bd94345ca
      7357:20120416:095015.794 === Registers: ===
      7357:20120416:095015.794 r8      =                0 =                    0 =                    0
      7357:20120416:095015.795 r9      =                0 =                    0 =                    0
      7357:20120416:095015.795 r10     =                0 =                    0 =                    0
      7357:20120416:095015.795 r11     =                a =                   10 =                   10
      7357:20120416:095015.795 r12     =          7731248 =            124981832 =            124981832
      7357:20120416:095015.795 r13     =                a =                   10 =                   10
      7357:20120416:095015.795 r14     =       3bd9751580 =         257051399552 =         257051399552
      7357:20120416:095015.795 r15     =       3bd950bca0 =         257049017504 =         257049017504
      7357:20120416:095015.795 rdi     =                0 =                    0 =                    0
      7357:20120416:095015.795 rsi     =                0 =                    0 =                    0
      7357:20120416:095015.795 rbp     =                0 =                    0 =                    0
      7357:20120416:095015.795 rbx     =                0 =                    0 =                    0
      7357:20120416:095015.795 rdx     =       3bd974f280 =         257051390592 =         257051390592
      7357:20120416:095015.795 rax     =                0 =                    0 =                    0
      7357:20120416:095015.795 rcx     =                0 =                    0 =                    0
      7357:20120416:095015.795 rsp     =     7fff0fdf92f0 =      140733459698416 =      140733459698416
      7357:20120416:095015.795 rip     =       3bd94345ca =         257048135114 =         257048135114
      7357:20120416:095015.795 efl     =            10283 =                66179 =                66179
      7357:20120416:095015.795 csgsfs  =               33 =                   51 =                   51
      7357:20120416:095015.795 err     =                4 =                    4 =                    4
      7357:20120416:095015.795 trapno  =                e =                   14 =                   14
      7357:20120416:095015.795 oldmask =                0 =                    0 =                    0
      7357:20120416:095015.795 cr2     =                0 =                    0 =                    0
      7357:20120416:095015.795 === Backtrace: ===
      7357:20120416:095015.795 12: /usr/bin/zabbix/zabbix_server(print_fatal_info+0xcd) [0x43967d]
      7357:20120416:095015.795 11: /usr/bin/zabbix/zabbix_server [0x438ed4]
      7357:20120416:095015.795 10: /lib64/libc.so.6 [0x3bd94302d0]
      7357:20120416:095015.795 9: /lib64/libc.so.6 [0x3bd94345ca]
      7357:20120416:095015.795 8: /usr/bin/zabbix/zabbix_server(DBget_item_from_db+0x24b) [0x45904b]
      7357:20120416:095015.795 7: /usr/bin/zabbix/zabbix_server(evaluate_expressions+0x8b0) [0x4503b0]
      7357:20120416:095015.795 6: /usr/bin/zabbix/zabbix_server [0x42f6a8]
      7357:20120416:095015.795 5: /usr/bin/zabbix/zabbix_server(DCsync_history+0xf29) [0x430779]
      7357:20120416:095015.795 4: /usr/bin/zabbix/zabbix_server(main_dbsyncer_loop+0xc9) [0x4100d9]
      7357:20120416:095015.795 3: /usr/bin/zabbix/zabbix_server(MAIN_ZABBIX_ENTRY+0x932) [0x40fa12]
      7357:20120416:095015.795 2: /usr/bin/zabbix/zabbix_server(daemon_start+0x21f) [0x438b3f]
      7357:20120416:095015.795 1: /lib64/libc.so.6(__libc_start_main+0xf4) [0x3bd941d994]
      7357:20120416:095015.795 0: /usr/bin/zabbix/zabbix_server [0x40b9f9]
      7357:20120416:095015.795 === Memory map: ===
      7357:20120416:095015.796 00400000-00481000 r-xp 00000000 08:03 404225                             /usr/bin/zabbix/zabbix_server
      7357:20120416:095015.796 00681000-006a6000 rw-p 00081000 08:03 404225                             /usr/bin/zabbix/zabbix_server
      7357:20120416:095015.796 006a6000-006ac000 rw-p 006a6000 00:00 0
      7357:20120416:095015.796 008a5000-008aa000 rw-p 000a5000 08:03 404225                             /usr/bin/zabbix/zabbix_server
      7357:20120416:095015.796 07726000-07763000 rw-p 07726000 00:00 0                                  [heap]
      7357:20120416:095015.796 3bd9000000-3bd901c000 r-xp 00000000 08:03 304651                         /lib64/ld-2.5.so
      7357:20120416:095015.796 3bd921b000-3bd921c000 r--p 0001b000 08:03 304651                         /lib64/ld-2.5.so
      7357:20120416:095015.796 3bd921c000-3bd921d000 rw-p 0001c000 08:03 304651                         /lib64/ld-2.5.so
      7357:20120416:095015.796 3bd9400000-3bd954e000 r-xp 00000000 08:03 304899                         /lib64/libc-2.5.so
      7357:20120416:095015.796 3bd954e000-3bd974d000 ---p 0014e000 08:03 304899                         /lib64/libc-2.5.so
      7357:20120416:095015.796 3bd974d000-3bd9751000 r--p 0014d000 08:03 304899                         /lib64/libc-2.5.so
      7357:20120416:095015.796 3bd9751000-3bd9752000 rw-p 00151000 08:03 304899                         /lib64/libc-2.5.so
      7357:20120416:095015.796 3bd9752000-3bd9757000 rw-p 3bd9752000 00:00 0
      7357:20120416:095015.796 3bd9800000-3bd9802000 r-xp 00000000 08:03 304904                         /lib64/libdl-2.5.so
      7357:20120416:095015.796 3bd9802000-3bd9a02000 ---p 00002000 08:03 304904                         /lib64/libdl-2.5.so
      7357:20120416:095015.796 3bd9a02000-3bd9a03000 r--p 00002000 08:03 304904                         /lib64/libdl-2.5.so
      7357:20120416:095015.796 3bd9a03000-3bd9a04000 rw-p 00003000 08:03 304904                         /lib64/libdl-2.5.so
      7357:20120416:095015.796 3bd9c00000-3bd9c82000 r-xp 00000000 08:03 304900                         /lib64/libm-2.5.so
      7357:20120416:095015.796 3bd9c82000-3bd9e81000 ---p 00082000 08:03 304900                         /lib64/libm-2.5.so
      7357:20120416:095015.796 3bd9e81000-3bd9e82000 r--p 00081000 08:03 304900                         /lib64/libm-2.5.so
      7357:20120416:095015.796 3bd9e82000-3bd9e83000 rw-p 00082000 08:03 304900                         /lib64/libm-2.5.so
      7357:20120416:095015.796 3bda000000-3bda016000 r-xp 00000000 08:03 304907                         /lib64/libpthread-2.5.so
      7357:20120416:095015.796 3bda016000-3bda215000 ---p 00016000 08:03 304907                         /lib64/libpthread-2.5.so
      7357:20120416:095015.796 3bda215000-3bda216000 r--p 00015000 08:03 304907                         /lib64/libpthread-2.5.so
      7357:20120416:095015.796 3bda216000-3bda217000 rw-p 00016000 08:03 304907                         /lib64/libpthread-2.5.so
      7357:20120416:095015.796 3bda217000-3bda21b000 rw-p 3bda217000 00:00 0
      7357:20120416:095015.796 3bda400000-3bda415000 r-xp 00000000 08:03 304910                         /lib64/libselinux.so.1
      7357:20120416:095015.796 3bda415000-3bda615000 ---p 00015000 08:03 304910                         /lib64/libselinux.so.1
      7357:20120416:095015.796 3bda615000-3bda617000 rw-p 00015000 08:03 304910                         /lib64/libselinux.so.1
      7357:20120416:095015.796 3bda617000-3bda618000 rw-p 3bda617000 00:00 0
      7357:20120416:095015.796 3bda800000-3bda83b000 r-xp 00000000 08:03 304909                         /lib64/libsepol.so.1
      7357:20120416:095015.796 3bda83b000-3bdaa3b000 ---p 0003b000 08:03 304909                         /lib64/libsepol.so.1
      7357:20120416:095015.796 3bdaa3b000-3bdaa3c000 rw-p 0003b000 08:03 304909                         /lib64/libsepol.so.1
      7357:20120416:095015.796 3bdaa3c000-3bdaa46000 rw-p 3bdaa3c000 00:00 0
      7357:20120416:095015.796 3bdac00000-3bdac14000 r-xp 00000000 08:03 399840                         /usr/lib64/libz.so.1.2.3
      7357:20120416:095015.796 3bdac14000-3bdae13000 ---p 00014000 08:03 399840                         /usr/lib64/libz.so.1.2.3
      7357:20120416:095015.796 3bdae13000-3bdae14000 rw-p 00013000 08:03 399840                         /usr/lib64/libz.so.1.2.3
      7357:20120416:095015.796 3bdb000000-3bdb08f000 r-xp 00000000 08:03 394021                         /usr/lib64/libnetsnmp.so.10.0.1
      7357:20120416:095015.796 3bdb08f000-3bdb28f000 ---p 0008f000 08:03 394021                         /usr/lib64/libnetsnmp.so.10.0.1
      7357:20120416:095015.796 3bdb28f000-3bdb293000 rw-p 0008f000 08:03 394021                         /usr/lib64/libnetsnmp.so.10.0.1
      7357:20120416:095015.796 3bdb293000-3bdb2c7000 rw-p 3bdb293000 00:00 0
      7357:20120416:095015.796 3bdb400000-3bdb415000 r-xp 00000000 08:03 304903                         /lib64/libnsl-2.5.so
      7357:20120416:095015.796 3bdb415000-3bdb614000 ---p 00015000 08:03 304903                         /lib64/libnsl-2.5.so
      7357:20120416:095015.796 3bdb614000-3bdb615000 r--p 00014000 08:03 304903                         /lib64/libnsl-2.5.so
      7357:20120416:095015.796 3bdb615000-3bdb616000 rw-p 00015000 08:03 304903                         /lib64/libnsl-2.5.so
      7357:20120416:095015.796 3bdb616000-3bdb618000 rw-p 3bdb616000 00:00 0
      7357:20120416:095015.796 3bdb800000-3bdb809000 r-xp 00000000 08:03 304905                         /lib64/libcrypt-2.5.so
      7357:20120416:095015.796 3bdb809000-3bdba08000 ---p 00009000 08:03 304905                         /lib64/libcrypt-2.5.so
      7357:20120416:095015.796 3bdba08000-3bdba09000 r--p 00008000 08:03 304905                         /lib64/libcrypt-2.5.so
      7357:20120416:095015.796 3bdba09000-3bdba0a000 rw-p 00009000 08:03 304905                         /lib64/libcrypt-2.5.so
      7357:20120416:095015.796 3bdba0a000-3bdba38000 rw-p 3bdba0a000 00:00 0
      7357:20120416:095015.796 3bdbc00000-3bdbc08000 r-xp 00000000 08:03 400022                         /usr/lib64/libwrap.so.0.7.6
      7357:20120416:095015.796 3bdbc08000-3bdbe07000 ---p 00008000 08:03 400022                         /usr/lib64/libwrap.so.0.7.6
      7357:20120416:095015.796 3bdbe07000-3bdbe09000 rw-p 00007000 08:03 400022                         /usr/lib64/libwrap.so.0.7.6
      7357:20120416:095015.796 3bdc000000-3bdc12d000 r-xp 00000000 08:03 304913                         /lib64/libcrypto.so.0.9.8e
      7357:20120416:095015.796 3bdc12d000-3bdc32c000 ---p 0012d000 08:03 304913                         /lib64/libcrypto.so.0.9.8e
      7357:20120416:095015.796 3bdc32c000-3bdc34d000 rw-p 0012c000 08:03 304913                         /lib64/libcrypto.so.0.9.8e
      7357:20120416:095015.797 3bdc34d000-3bdc351000 rw-p 3bdc34d000 00:00 0
      7357:20120416:095015.797 3bdc400000-3bdc402000 r-xp 00000000 08:03 304912                         /lib64/libcom_err.so.2.1
      7357:20120416:095015.797 3bdc402000-3bdc601000 ---p 00002000 08:03 304912                         /lib64/libcom_err.so.2.1
      7357:20120416:095015.797 3bdc601000-3bdc602000 rw-p 00001000 08:03 304912                         /lib64/libcom_err.so.2.1
      7357:20120416:095015.797 3bdc800000-3bdc820000 r-xp 00000000 08:03 399852                         /usr/lib64/libpq.so.4.1
      7357:20120416:095015.797 3bdc820000-3bdca20000 ---p 00020000 08:03 399852                         /usr/lib64/libpq.so.4.1
      7357:20120416:095015.797 3bdca20000-3bdca22000 rw-p 00020000 08:03 399852                         /usr/lib64/libpq.so.4.1
      7357:20120416:095015.797 3bdcc00000-3bdcc02000 r-xp 00000000 08:03 304776                         /lib64/libkeyutils-1.2.so
      7357:20120416:095015.797 3bdcc02000-3bdce01000 ---p 00002000 08:03 304776                         /lib64/libkeyutils-1.2.so
      7357:20120416:095015.797 3bdce01000-3bdce02000 rw-p 00001000 08:03 304776                         /lib64/libkeyutils-1.2.so
      7357:20120416:095015.797 3bdd400000-3bdd431000 r-xp 00000000 08:03 398849                         /usr/lib64/libidn.so.11.5.19
      7357:20120416:095015.797 3bdd431000-3bdd630000 ---p 00031000 08:03 398849                         /usr/lib64/libidn.so.11.5.19
      7357:20120416:095015.797 3bdd630000-3bdd631000 rw-p 00030000 08:03 398849                         /usr/lib64/libidn.so.11.5.19
      7357:20120416:095015.797 3bdd800000-3bdd811000 r-xp 00000000 08:03 304902                         /lib64/libresolv-2.5.so
      7357:20120416:095015.797 3bdd811000-3bdda11000 ---p 00011000 08:03 304902                         /lib64/libresolv-2.5.so
      7357:20120416:095015.797 3bdda11000-3bdda12000 r--p 00011000 08:03 304902                         /lib64/libresolv-2.5.so
      7357:20120416:095015.797 3bdda12000-3bdda13000 rw-p 00012000 08:03 304902                         /lib64/libresolv-2.5.so
      7357:20120416:095015.797 3bdda13000-3bdda15000 rw-p 3bdda13000 00:00 0
      7357:20120416:095015.797 3bddc00000-3bddc3b000 r-xp 00000000 08:03 399520                         /usr/lib64/libcurl.so.3.0.0
      7357:20120416:095015.797 3bddc3b000-3bdde3b000 ---p 0003b000 08:03 399520                         /usr/lib64/libcurl.so.3.0.0
      7357:20120416:095015.797 3bdde3b000-3bdde3d000 rw-p 0003b000 08:03 399520                         /usr/lib64/libcurl.so.3.0.0
      7357:20120416:095015.797 3bde400000-3bde444000 r-xp 00000000 08:03 304914                         /lib64/libssl.so.0.9.8e
      7357:20120416:095015.797 3bde444000-3bde644000 ---p 00044000 08:03 304914                         /lib64/libssl.so.0.9.8e
      7357:20120416:095015.797 3bde644000-3bde64a000 rw-p 00044000 08:03 304914                         /lib64/libssl.so.0.9.8e
      7357:20120416:095015.797 3bde800000-3bde808000 r-xp 00000000 08:03 398883                         /usr/lib64/libkrb5support.so.0.1
      7357:20120416:095015.797 3bde808000-3bdea07000 ---p 00008000 08:03 398883                         /usr/lib64/libkrb5support.so.0.1
      7357:20120416:095015.797 3bdea07000-3bdea08000 rw-p 00007000 08:03 398883                         /usr/lib64/libkrb5support.so.0.1
      7357:20120416:095015.797 3bdec00000-3bdec2c000 r-xp 00000000 08:03 399851                         /usr/lib64/libgssapi_krb5.so.2.2
      7357:20120416:095015.797 3bdec2c000-3bdee2c000 ---p 0002c000 08:03 399851                         /usr/lib64/libgssapi_krb5.so.2.2
      7357:20120416:095015.797 3bdee2c000-3bdee2e000 rw-p 0002c000 08:03 399851                         /usr/lib64/libgssapi_krb5.so.2.2
      7357:20120416:095015.797 3bdf000000-3bdf024000 r-xp 00000000 08:03 399849                         /usr/lib64/libk5crypto.so.3.1
      7357:20120416:095015.797 3bdf024000-3bdf223000 ---p 00024000 08:03 399849                         /usr/lib64/libk5crypto.so.3.1
      7357:20120416:095015.797 3bdf223000-3bdf225000 rw-p 00023000 08:03 399849                         /usr/lib64/libk5crypto.so.3.1
      7357:20120416:095015.797 3bdf800000-3bdf891000 r-xp 00000000 08:03 399850                         /usr/lib64/libkrb5.so.3.3
      7357:20120416:095015.797 3bdf891000-3bdfa91000 ---p 00091000 08:03 399850                         /usr/lib64/libkrb5.so.3.3
      7357:20120416:095015.797 3bdfa91000-3bdfa95000 rw-p 00091000 08:03 399850                         /usr/lib64/libkrb5.so.3.3
      7357:20120416:095015.797 2aab0d74b000-2aab0d74d000 rw-p 2aab0d74b000 00:00 0
      7357:20120416:095015.797 2aab0d759000-2aab0d763000 rw-p 2aab0d759000 00:00 0
      7357:20120416:095015.797 2aab0d763000-2aab0d76d000 r-xp 00000000 08:03 304863                     /lib64/libnss_files-2.5.so
      7357:20120416:095015.797 2aab0d76d000-2aab0d96c000 ---p 0000a000 08:03 304863                     /lib64/libnss_files-2.5.so
      7357:20120416:095015.797 2aab0d96c000-2aab0d96d000 r--p 00009000 08:03 304863                     /lib64/libnss_files-2.5.so
      7357:20120416:095015.797 2aab0d96d000-2aab0d96e000 rw-p 0000a000 08:03 304863                     /lib64/libnss_files-2.5.so
      7357:20120416:095015.797 2aab0d96e000-2aab0e177000 rw-s 00000000 00:09 5308427                    /SYSV68035772 (deleted)
      7357:20120416:095015.797 2aab0e177000-2aab0f178000 rw-s 00000000 00:09 5341196                    /SYSV78035772 (deleted)
      7357:20120416:095015.797 2aab0f178000-2aab0f579000 rw-s 00000000 00:09 5373966                    /SYSV74035772 (deleted)
      7357:20120416:095015.797 2aab0f579000-2aab0fc46000 rw-s 00000000 00:09 5406735                    /SYSV67035772 (deleted)
      7357:20120416:095015.797 2aab0fc46000-2aab0fd7a000 rw-s 00000000 00:09 5439504                    /SYSV73035772 (deleted)
      7357:20120416:095015.797 2aab0fd7a000-2aab0fd7c000 rw-s 00000000 00:09 5472273                    /SYSV53035772 (deleted)
      7357:20120416:095015.797 2aab0fd7c000-2aab0fd7d000 rw-p 2aab0fd7c000 00:00 0
      7357:20120416:095015.797 2aab0fd89000-2aab0fd96000 r-xp 00000000 08:03 304901                     /lib64/libgcc_s-4.1.2-20080102.so.1
      7357:20120416:095015.797 2aab0fd96000-2aab0ff96000 ---p 0000d000 08:03 304901                     /lib64/libgcc_s-4.1.2-20080102.so.1
      7357:20120416:095015.797 2aab0ff96000-2aab0ff97000 rw-p 0000d000 08:03 304901                     /lib64/libgcc_s-4.1.2-20080102.so.1
      7357:20120416:095015.797 7fff0fde7000-7fff0fe0d000 rw-p 7ffffffd9000 00:00 0                      [stack]
      7357:20120416:095015.797 ffffffffff600000-ffffffffffe00000 ---p 00000000 00:00 0                  [vdso]
      7357:20120416:095015.797 ================================
      7357:20120416:095015.797 Please consider attaching a disassembly listing to your bug report.
      7357:20120416:095015.797 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
      7319:20120416:095015.798 One child process died (PID:7357,exitcode/signal:255). Exiting ...
      7319:20120416:095015.798 zbx_on_exit() called
      7322:20120416:095015.798 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7324:20120416:095015.799 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7325:20120416:095015.800 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7327:20120416:095015.800 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7328:20120416:095015.801 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7330:20120416:095015.801 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7329:20120416:095015.802 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7348:20120416:095015.802 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7351:20120416:095015.802 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7332:20120416:095015.803 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7353:20120416:095015.803 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7350:20120416:095015.803 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7345:20120416:095015.804 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7356:20120416:095015.804 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7359:20120416:095015.804 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7360:20120416:095015.804 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7361:20120416:095015.805 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7362:20120416:095015.805 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7363:20120416:095015.806 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7364:20120416:095015.806 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7336:20120416:095015.806 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7338:20120416:095015.807 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7344:20120416:095015.808 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7341:20120416:095015.808 Got signal [signal:15(SIGTERM),sender_pid:7319,sender_uid:502,reason:0]. Exiting ...
      7319:20120416:095017.807 In DBconnect() flag:1
      7319:20120416:095017.808 query [txnlev:0] [select oid from pg_type where typname='bytea']
      7319:20120416:095017.809 PostgreSQL Server version: 80111
      7319:20120416:095017.809 query [txnlev:0] [set escape_string_warning to off]
      7319:20120416:095017.809 query [txnlev:0] [show standard_conforming_strings]
      7319:20120416:095017.809 End of DBconnect():0
      7319:20120416:095017.809 In free_database_cache()
      7319:20120416:095017.809 In DCsync_all()
      7319:20120416:095017.810 In DCsync_history() history_first:59 history_num:0
      7319:20120416:095017.810 syncing history data...
      7319:20120416:095017.810 syncing history data done
      7319:20120416:095017.810 In DCsync_trends() trends_num:0
      7319:20120416:095017.810 syncing trends data...
      7319:20120416:095017.810 query [txnlev:1] [begin;]
      7319:20120416:095017.810 query [txnlev:1] [commit;]
      7319:20120416:095017.810 syncing trends data done
      7319:20120416:095017.810 End of DCsync_trends()
      7319:20120416:095017.810 End of DCsync_all()
      7319:20120416:095017.810 In zbx_mem_destroy() descr:'history cache'
      7319:20120416:095017.810 End of zbx_mem_destroy()
      7319:20120416:095017.810 In zbx_mem_destroy() descr:'history text cache'
      7319:20120416:095017.810 In zbx_mem_destroy() descr:'trend cache'
      7319:20120416:095017.810 End of free_database_cache()
      7319:20120416:095017.810 In free_configuration_cache()
      7319:20120416:095017.810 In zbx_mem_destroy() descr:'configuration cache'
      7319:20120416:095017.810 In zbx_strpool_destroy()
      7319:20120416:095017.810 In zbx_mem_destroy() descr:'string pool'
      7319:20120416:095017.810 End of zbx_strpool_destroy()
      7319:20120416:095017.810 End of free_configuration_cache()
      7319:20120416:095017.810 In free_selfmon_collector() collector:0x2aab0fd7a000
      7319:20120416:095017.810 End of free_selfmon_collector()
      7319:20120416:095017.810 Zabbix Server stopped. Zabbix 1.8.11 (revision 26205).
