Zabbix: 1.8.11
Centos 6.2 (64-bt)
PHP: 5.3.3
Apache: 2.2.15
I'm new to Zabbix, first time installation. The prerequisites check is failing of the following php configurations:
post_max_size
max_execution_size
max_input_time
timezone.
I have corrected these setting in /etc/php.ini however it appears the settings/or file are not being read. I have searched for other copies of php.ini and can find none. /etc/php.ini is the only copy.
phpinfo(); confirms the etc/php.ini is the loaded configuration file.
Any help/suggestions would be greatly appreciated.
Thanks,
Mark.
Centos 6.2 (64-bt)
PHP: 5.3.3
Apache: 2.2.15
post_max_size
max_execution_size
max_input_time
timezone.
Thanks,
Mark.
