Autoregistration not working as expected
  • Filter
    I'm struggling to get autoregistration working correctly.
    I have 2 rules under action for autoregistration to distinguish between hostnames.
    Our hostnames contain a letter v for virtual or a p for physical machines. Some physical machines might not have a p in their name but all virtual ones do.
    example:
    gedadvl100 = virtual
    gedadpl100 = physical
    so the two rules are as follows:
    hostname not like gedadvl
    add to group physical
    hostname like gedadvl
    add to group virtual
    But it looks like is not doing what it should. Machines with gedadvl are added to the physical hostgroup. I have tried using regex like:
    [[:upper:]^gedadvl][0-9]{0,4}
    and saved it under regular expressions and the test works fine.
    Can I use a regex here?
    Anyone?
    I mean this would be great. But Host name not like doesn't seem to accept regex.
      Ok, I have now skipped using the autoregistration as it is not working as expected.
      Is it possible to use one discovery rule with two zabbix agent keys?
      e.g.
      sytem.hostname and system.uname?
      I tried it and it doesn't seem to work.
        I stumbled upon the same issue. I looked at the sources and apparently Zabbix only does substring match instead of regex one. Reported here https://support.zabbix.com/browse/ZBX-5199
        Announcement
        No announcement yet.
