UTF-8 problem
  • Cimba
    • Mar 2012
    UTF-8 problem
    I have a problem with accents in french perf_counter. I tried several things as perf_counter item, vbs script with UserParameter, using id instead of names in performance counters.
    Anything works realy: vbs solution doesn't works with accent perf counters, id are not the same on x86 and x86_64 systems, and perf_counter don't work with accents.
    I saw that frontend and zabbix_server/zabbix_agent are utf-8 compliant. So is there a way to configure an item with an accent without geting a "??" in place of the accent after saving ?
    Thank your for your answer.
    Regards,
    Olivier.
