VIEW ICONS OR ELEMENTS Zabbix 1.8.11
  • fraggle
    • Mar 2012
    • 14
    Hello. I am new to Zabbix but as an Administrator have been given responsibility to configure it from a monitoring system point of view. Whilst I am quite happy I have a couple of questions:
    1. When I create a Map and I bring in a "New Element" which may be a "workstation". There are many other ICONS available but I simply cannot work out how to view all these Icons in a single place/folder. Can anyone help please?
    2. I want to bring in some other Icons that I got from the zabbix website, these are all .png 100 x 100. So I go to my map called "home", place a tick in the box on the right & select "import map", the import box opens. As I only want to import an Icon I deselect everything else but leave "Icon - Add Missing" ticked, browse to the folder my icons are in and select my .png Icon. I then get an error message "ERROR: Import Failed
    XML file contains errors. Fatal Error 4: Start tag expected, '<' not found [line:1|Column:1]
    I would be extremely thankful for any help - kind regards Fraggle
  • ghoz
    • May 2011
    • 204
    take a look a administration / general / images (right drop down menu)
    Images in zabbix are in the database...
    and the import Map functionality is for importing xml description of a map (that can include images base64 encoded)
    Ghoz
    • fraggle
      • Mar 2012
      • 14
      Ghoz - thanks for your reply, but if you look at question 2 it appears as an error, surely this is not correct from the simple matter of importing and icon?
      fraggle
      • fraggle
        • Mar 2012
        • 14
        GHOZ, Thanks again, having read it properly I now understand and it works fine
