webinterface: ping host behind proxy
  • marsipulami
    • May 2012
    • 18
    Hey all,
    i am new to this forum so i am sorry if this topic is in the wrong forum.
    In the Zabbix webinterface(Zabbix 1.8.11) it is possible to ping or trace a host. For example if that host triggerd an event.
    This works nice and all, ping as well as trace, but here is the problem. I have severall hosts that are monitored by a zabbix proxy.
    The monitoring is great, but the ping/trace command from the webinterface is not able to ping hosts that are monitored by the proxy.
    Is there a fix/patch/workaround that makes the script that way that it determines if the host is behind a zabbix proxy and then lets the proxy execute the ping/trace from the webinterface?
    If not, i have to script it myself
    Sorry for my english if it is not very good.
  • marsipulami
    • May 2012
    • 18
    Is nobody using proxies? maybe you can test some for me?
