Zabbix API and usermacro
  • ronfulkerson
    • May 2012
    Hello All,
    I am trying to obtain the value of a usermacro defined in a host or template with Zabbix 1.8.10. I am sending the following json command which specifies the macro using a filter:
    {"auth":"ce1e2f5efef9d18abfdb128fbdd625b2","method":"usermacro.get","id":1,"params":{"filter":{"macro":"{$MACROTEST}"}},"jsonrpc":"2.0"}
    and I receive the response:
    {"jsonrpc":"2.0","result":[{"hostmacroid":"4"}],"id":1}
    While the request and response seem valid, it is not the response I expected. The documentation indicates a number of items returned in the response, including the macro's associated value. Please see this reference.
    Is there a setting that I need to enable or some other change I need to make? Thanks for your help!
  • ronfulkerson
    • May 2012
    I found the issue. I needed to indicate extended output in the parameters section of the request:
    "output": "extend"
    Thanks.
