SNMP error [1]
  • SergeyAB
    • May 2012
    • 9
    SNMP error [1]
    Hi!
    Debian 6.0.4 / Zabbix 1.8.2 / NET-SNMP version: 5.4.3
    Zabbix:/var/log/zabbix-server# ldd /usr/local/sbin/zabbix_server |grep snmp
    libsnmp.so.15 => /usr/lib/libsnmp.so.15 (0x00007f1aba840000)
    DebugLevel=3
    PHP Code:
    snmp_build: unknown failure  3294:20120505:094111.546 Item [u010201:link_left_status] error: SNMP error [1]
    snmp_build: unknown failure  3294:20120505:094112.757 Item [u011104:link_right_status] error: SNMP error [1]
    DebugLevel=4
    PHP Code:
    7629:20120505:103834.653 In substitute_simple_macros (data:'link_right_status')
    7629:20120505:103834.653 In get_value() key:'link_right_status'
    7629:20120505:103834.653 In get_value_snmp() key:'link_right_status' oid:'interfaces.ifTable.ifEntry.ifOperStatus.26'
    7629:20120505:103834.653 In snmp_open_session()
    7629:20120505:103834.653 SNMP [public@10.0.61.76:161]
    7629:20120505:103834.653 End of snmp_open_session()
    7629:20120505:103834.653 Standard processing
    7629
    :20120505:103834.653 In snmp_normalize(oid:interfaces.ifTable.ifEntry.ifOperStatus.26)
    7629:20120505:103834.653 End of snmp_normalize():interfaces.ifTable.ifEntry.ifOperStatus.26
    7629
    :20120505:103834.653 In get_snmp(oid:interfaces.ifTable.ifEntry.ifOperStatus.26)
    No log handling enabled - turning on stderr logging
    snmp_build
    : unknown failure  7629:20120505:103834.653 Status send [1]
    7629:20120505:103834.653 End of get_snmp():NOTSUPPORTED
    7629
    :20120505:103834.653 In snmp_close_session()
    7629:20120505:103834.653 End of snmp_close_session()
    7629:20120505:103834.653 End of get_value_snmp():NOTSUPPORTED
    7629
    :20120505:103834.653 Item [u011712:link_right_status] error: SNMP error [1]
    7629:20120505:103834.653 In zabbix_log()
    7629:20120505:103834.653 In DCconfig_get_items() hostid:0 key:'zabbix[log]'
    Trouble: Zabbix doesn't want to use with SNMP.
    snmpwalk return valid results, but Zabbix doesn't.
    I tried to update my OS and Zabbix and have this problem atm.
    I've new clean installation of Debian and Zabbix on other hardware.
    I tried to export my hosts/items/triggers from old installation to new, but i've some errors and have no any good result for this: a lot of lost items and triggers.
    I tried to export full sql dump from old installation to new (with mysqldump utility), but i've again the same error: SNMP error [1].
    I tried to upgrade Zabbix only to 1.8.3 and 1.8.12 - nothing.
    I tried to compile Zabbix from sources - nothing.
    I tried to remove all zabbix related packeges and install them all again - nothing.
    Help me, how to fix?
  • SergeyAB
    • May 2012
    • 9
    problem solved:
    after system/zabbix update i found items with wrong prefix, for example:
    interfaces.ifTable.ifEntry.ifInOctets.3 instead of ifInOctets.3
    that is why special oids didn't work correctly. i dont known how i did this :]
