Hello all !
It's been 3 days I am trying to fix this problem, I read forums and triple checked everything, but I cannot make it work.
Using zabbix release : 1.8.12
Agent and server are exact same release.
Configured an agent with zabbix_agentd.conf :
Server=serverip
Hostname=tg_front2
Everything is default. Configured iptables so that iptables --list contains :
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:zabbix-trapper
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:zabbix-agent
On the server :
Configured DBName, DBUser, DBPassword and DBPort properly.
ListenPort=10051
Server is started through /etc/init.d/zabbix_server_ctl start.
Running OK (seems to).
Server also has zabbix_agentd running with following (default) configuration :
Server=127.0.0.1
Hostname=Zabbix server
Web frontend works perfectly.
First :
I switched the default existing host "Zabbix server" to monitored in the web UI.
=> The availability flag stays gray
I created a host called "tg_front2" with its IP and Template_Linux : It shows OK in the list : 10 apps, 102 items, 44 Triggers.
The availability flag remains gray.
Here is the server log at startup :
1426:20120511:134850.455 Starting Zabbix Server. Zabbix 1.8.12 (revision 27054).
1426:20120511:134850.455 ****** Enabled features ******
1426:20120511:134850.455 SNMP monitoring: YES
1426:20120511:134850.455 IPMI monitoring: YES
1426:20120511:134850.455 WEB monitoring: YES
1426:20120511:134850.455 Jabber notifications: YES
1426:20120511:134850.455 Ez Texting notifications: YES
1426:20120511:134850.455 ODBC: NO
1426:20120511:134850.455 SSH2 support: NO
1426:20120511:134850.455 IPv6 support: NO
1426:20120511:134850.456 ******************************
1429:20120511:134850.470 server #2 started [db watchdog #1]
1428:20120511:134850.471 server #1 started [configuration syncer #1]
1436:20120511:134850.491 server #9 started [trapper #1]
1437:20120511:134850.491 server #10 started [trapper #2]
1438:20120511:134850.492 server #11 started [trapper #3]
1445:20120511:134850.503 server #13 started [trapper #5]
1447:20120511:134850.505 server #14 started [icmp pinger #1]
1448:20120511:134850.514 server #15 started [alerter #1]
1449:20120511:134850.518 server #16 started [housekeeper #1]
1449:20120511:134850.518 executing housekeeper
1450:20120511:134850.522 server #17 started [timer #1]
1451:20120511:134850.523 server #18 started [http poller #1]
1426:20120511:134850.537 server #0 started [main process]
1444:20120511:134850.538 server #12 started [trapper #4]
1462:20120511:134850.542 server #20 started [history syncer #1]
1463:20120511:134850.543 server #21 started [history syncer #2]
1464:20120511:134850.546 server #22 started [history syncer #3]
1465:20120511:134850.558 server #23 started [history syncer #4]
1466:20120511:134850.563 server #24 started [escalator #1]
1467:20120511:134850.563 server #25 started [proxy poller #1]
1468:20120511:134850.566 server #26 started [self-monitoring #1]
1432:20120511:134850.757 server #5 started [poller #3]
1431:20120511:134850.764 server #4 started [poller #2]
1430:20120511:134850.766 server #3 started [poller #1]
1433:20120511:134850.770 server #6 started [poller #4]
1434:20120511:134850.772 server #7 started [poller #5]
1435:20120511:134850.775 server #8 started [unreachable poller #1]
1461:20120511:134850.791 server #19 started [discoverer #1]
1449:20120511:134850.847 housekeeper deleted: 0 records from history and trends, 0 records of deleted items, 0 events, 0 alerts, 0 sessions
And then the problematic logs :
1444:20120511:135002.558 Sending list of active checks to [127.0.0.1] failed: host [Zabbix server] not found
1444:20120511:135006.435 Sending list of active checks to [176.31.249.208] failed: host [tg_front2] not found
It seems that client can talk to the server but the server cannot retrieve the info from the hostname. Hostname from zabbix_agentd.conf and Name of the host in the webUI matches perfectly.
telnet of the agent from server on port 10050 works OK.
I am totally lost. All posts that I have seen on the forums indicate a difference between agent configured host name and server host name. But in my situation it matches.
I checked that the zabbix user for mysql can select properly the "hosts" table and it can, showing the correct entries.
I can provide any information needed. I do want to use zabbix because I'm used to it, but i am about to give up.
Please help !
Thank you so much for any help.
Christophe.
Server=serverip
Hostname=tg_front2
On the server :
ListenPort=10051
Server=127.0.0.1
First :
Please help !
Christophe.
