Zabbix on Solaris 9 and Oracle
  • addyrocker
    • Sep 2009
    • 11
    Hello all,
    I'm currently having a bit of a pickle installing the latest zabbix server on a solaris 9 machine with oracle 10g, I'm trying to compile with the following options
    HTML Code:
    ./configure --enable-server --with-oracle --with-net-snmp --with-libcurl
    I have all the packages along with dependencies installed, the configure part runs fine its during the make install part that I've run into a snag with the error message pasted below
    HTML Code:
    cc -DZABBIX_DAEMON -g   -I/export/home/oracle/OraHome1/rdbms/public -I/export/ho
    me/oracle/OraHome1/rdbms/demo      -I. -I/opt/csw/include  -L/export/home/oracle
    /OraHome1/lib32     -L/opt/csw/lib -lcurl -lidn -lssl -lcrypto -lsocket -lnsl -l
    z  -L/opt/csw/lib -L/opt/csw/lib -lnetsnmp -lnsl -lsocket -lelf -lkstat -lcrypto
     -o zabbix_server zabbix_server-actions.o  zabbix_server-operations.o  zabbix_se
    rver-events.o zabbix_server-zlog.o  zabbix_server-server.o alerter/libzbxalerter
    .a  dbsyncer/libzbxdbsyncer.a dbconfig/libzbxdbconfig.a  discoverer/libzbxdiscov
    erer.a pinger/libzbxpinger.a  poller/libzbxpoller.a housekeeper/libzbxhousekeepe
    r.a  timer/libzbxtimer.a trapper/libzbxtrapper.a  nodewatcher/libzbxnodewatcher.
    a utils/libzbxutils.a  httppoller/libzbxhttppoller.a watchdog/libzbxwatchdog.a
    escalator/libzbxescalator.a proxypoller/libzbxproxypoller.a  selfmon/libzbxselfm
    on.a  ../../src/libs/zbxsysinfo/libzbxserversysinfo.a  ../../src/libs/zbxsysinfo
    /solaris/libspecsysinfo.a  ../../src/libs/zbxsysinfo/common/libcommonsysinfo.a
    ../../src/libs/zbxsysinfo/simple/libsimplesysinfo.a  ../../src/libs/zbxlog/libzb
    xlog.a  ../../src/libs/zbxdbcache/libzbxdbcache.a  ../../src/libs/zbxmemory/libz
    bxmemory.a  ../../src/libs/zbxalgo/libzbxalgo.a  ../../src/libs/zbxnix/libzbxnix
    .a  ../../src/libs/zbxsys/libzbxsys.a  ../../src/libs/zbxconf/libzbxconf.a  ../.
    ./src/libs/zbxmedia/libzbxmedia.a  ../../src/libs/zbxcommon/libzbxcommon.a  ../.
    ./src/libs/zbxcrypto/libzbxcrypto.a  ../../src/libs/zbxcomms/libzbxcomms.a  ../.
    ./src/libs/zbxcommshigh/libzbxcommshigh.a  ../../src/libs/zbxjson/libzbxjson.a
    ../../src/libs/zbxexec/libzbxexec.a  ../../src/libs/zbxself/libzbxself.a  ../../
    src/libs/zbxserver/libzbxserver.a  ../../src/libs/zbxicmpping/libzbxicmpping.a
    ../../src/libs/zbxdbhigh/libzbxdbhigh.a  ../../src/libs/zbxdb/libzbxdb.a    -lcl
    ntsh -lnnz10    -lcurl  -lnetsnmp -lkvm -lm -lnsl -lkstat -lsocket  -lresolv
    Undefined                       first referenced
     symbol                             in file
    round                               ../../src/libs/zbxserver/libzbxserver.a(eval
    func.o)
    ld: fatal: Symbol referencing errors. No output written to zabbix_server
    *** Error code 1
    make: Fatal error: Command failed for target `zabbix_server'
    Current working directory /export/home/zabbix/zabbix/src/zabbix_server
    *** Error code 1
    make: Fatal error: Command failed for target `install-recursive'
    *** Error code 1
    *** Error code 1
    I've tried with gcc and sun studio 12 also tried different versions of zabbix as well, gmake didnt work either, configuring with below option also didnt work
    HTML Code:
    Its always an error message pertaining to evalfunc.o during make install
    Any help in this matter would be appreciated!
