Zabbix agent does not pick up agent.ping change (from pull to active)
  • alledm
    • May 2012
    • 84
    I am monitoring 144 hosts through zabbix mainly rc3, and some rc4.
    Today I switched the agent.ping item from "normal" to "active".
    Some hosts did not pick up the change, and after minutes (~25 min) were still not reporting back.
    Putting one of them in debug, and testing again, I see:
    32634:20120518:160727.127 refresh_active_checks('zabbix.XXXX.com',10051)
     32634:20120518:160727.129 Sending [{
            "request":"active checks",
            "host":"HOSTNAME.XXXX.com"}]
     32634:20120518:160727.129 Before read
     32634:20120518:160727.130 Got [{
            "response":"success",
            "data":[
                            "key":"agent.ping",
                            "delay":10,
                            "lastlogsize":0,
                            "mtime":0},
    and
    32634:20120518:160727.130 In add_check('agent.ping', 10, 0, 0)
    but then I don't see the agent.ping being sent back, and the queue starts building up ( strangely always 45 of them, so it must be something different on those systems).
    Do you have any idea on how to debug it further?
    How can I file a bug if I don't have a support package?
    Regards
    Alessandro
  • alledm
    • May 2012
    • 84
    Is ther anyone that can give me an answer?
